Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit Logo
Anonymous Posted on Sep 01, 2008
Nail Gun how to
How to measure the compressor power?
Anonymous
Level 3:
President:
  • Master 2,712 Answers
  • Posted on Sep 01, 2008
Anonymous
Master
Level 3:
President:
Answers
2712
Questions
Helped
724184
Points
8771
One of the factors used to designate compressor power is motor horsepower. However, this isn't the best indicator. You really need to know the amount of air the compressor can deliver at a specific pressure. The rate at which a compressor can deliver a volume of air is noted in cubic feet per minute (cfm). Because atmospheric pressure plays a role in how fast air moves into the cylinder, cfm will vary with atmospheric pressure. It also varies with the temperature and humidity of the air. To set an even playing field, makers calculate standard cubic feet per minute (scfm) as cfm at sea level with 68 degrees F air at 36% relative humidity. Scfm ratings are given at a specific pressure–3.0 scfm at 90 psi, for example. If you reduce pressure, scfm goes up, and vice versa. You also may run across a rating called displacement cfm. This figure is the product of cylinder displacement and motor rpm. In comparison with scfm, it provides an index of compressor pump efficiency. The cfm and psi ratings are important because they indicate the tools that a particular compressor can drive. When choosing a compressor, make sure it can supply the amount of air and the pressure that your tools need.
I have a Bostitch 2.5 Gallon Compressor and nail gun. The compressor is working but the nail gun does not seem to be getting air through the hose. Any guidance?
compressor not compressing air --- problem reed valves or poppet valves in the compressor head
blocked supply tap to air line
air line not properly connected
check compressor tank air pressure gauge
tip
Power nail/staple gun
The worst pneumatic nail/staple gun is still better than the best electric nail/staple gun.
4answers
Aeg nail gun
Ask once and wait?
Nail gun air compressor
A good nail gun will regulate the pressure.
I want to use a 120psi brad nail gun on a clarke ranger 115psi compressor ..will it be ok
It'll be perfectly fine. Wear safety glasses with them nail guns, they can really send a nail flying.
lp
I have a craftsman nail gun with compressor, how do I load the nail in the gun?
the gun has a long case under the hand grip at the end there is a lever you must lift up on it. slide it open place nails inside close it and your ready.
PC nail gun does not work all the time. nails do
You have to oil the nailer with pneumatic oil, or you're using the wrong size nail
2answers
How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
Nail Gun cost
A good-quality starter set, including both a compressor and a small nail gun, can be bought for around 200 US dollars (USD). More sophisticated models can reach 1000 USD or more. Optional features such as a hard-shell case, safety trigger, and depth adjustment can drive the price even higher. For one-time jobs, a nail gun can also be rented at hardware stores and home repair centers.
3helpful
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Top Dewalt Air Tools & Compressors Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
