Normally when the refrigerator side freezes, it's because of an air flow problem. It can be caused from a stuck or defective air diffuser, a control board or sensor if this model has them or a thermostat, if it has one. You can check the temperature in the freezer section, to see if it's getting too cold (below zero). To check the temperature, place a thermometer between some packages. Air temperature is not a good check. If it is too cold, it can also cause the fridge section to get too cold. Usually, adjusting the control, to a slighlty warmer setting, will correct this.
