MY 2005 32INCH RCA TV MODEL # 32V432T SCREEN TURNS PINK WHEN YOU TURN IT ON .THEN GETS DARKER WHEN TV WARMS UP LIKE A RED COLOR. CHARACTERS FACES GET SUPER PINK...! WHAT MIGHT THIS BE ?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
This is not the tube, it's most likely the colour controller and system function ic has gotten scrambled, taking this to a tech to re program should not cost more than about $150 AU
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
