Question about Garden
Whitch spark plug for homelite chainsaw timberman 45
  • 58 Answers
Champion RCJ6Y
Posted on Jul 30, 2011
Anonymous
SOURCE:
Homelite Timberman 45 chainsaw runs fine but will not idle. Ideas?
dirty carb specifically in the idle jet turn it in till it bottoms . do not force more then return to the same place it was set if 3/4 turn in turn out 3/4 see if it works better .
Feb 16, 2015 | Homelite Garden
Zama carb pulls gas when not running
throw the carb out and buy a new one. there is an internal issue that can not be fixed
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Mar 20, 2013 | Homelite Garden
Can you email the page on how to tighten the chain on timberman 45 model...lost my manual. thks Dennis draralbee@msn;.com
This page will help. You may not find your exact model but just find one thats close
Good Luck and BE SAFE
Follow link below cut and paste in address bar
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_chainsaw_product_list.html
Feb 07, 2011 | Homelite Garden
Timberman 45 w/18 inch blade No owners manual Chain on in grooves and sprockets. Nuts tight Just a little loose. How do I Tighten chain?
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
You can request a new OM and while at it an IPL here:
https://register.homelite.com/contact_us/new
Please do.
Lou
Apr 14, 2010 | Homelite Garden
Homelite Timberman chainsaw won't run anymore
ohhhh maybe ya burnt a hole in top of piston... are you SURE compression is OK?
Feb 13, 2010 | Garden
Old gas, will not start. homelite "timberman 45"
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 30, 2009 | Homelite Garden
I have a Homelite timberman 45. It won't idle.
been out fighting 2 saws today,r+r lines filters one problem on 1 saw same went from 50/1 to 30/1 quit over heating and evaporating gas,, pulls easier fires an pulls chain well on big cuts//used 50on two cords cool day last year today 80+ over heated
Mar 21, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Fix bar brake on homelite timberman 45
It's a design flaw in timberman chain saws. After some hours of use, they develop a bad habit of not releasing the clutch drum completely. And that takes precious power away from the saw. If it becomes too tight, the clutch drum may over heat and cause the plastic enclosure to warp or melt down. After messing with this brake for months, I ended up completely removing it. Replacing it was not an option for me - there was nothing to replace - it is not the brake band that's bad, but the mechanism in the brake handle of this saw that is flawed. Overall, this chainsaw is very cheaply built - Homelite used waaaay too much plastic in it!
Oct 12, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
296 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
