You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
http://waterheatertimer.org/Low-hot-water-pressure.html
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
