I have a lcd 42 inch hd insignia tv model # ns-lcd42hd it came originally with a tv stand and i removed the stand and mounted it on the wall now i am trying to convert back to the tv stand but i lost the screws and i am trying to find out what size screws to use to put my tv back on the stand
We lost the screws to the stand for an LG lcd flatscreen model
# LG37LC2D-UD. The stand model # is 49509K0221AWe lost the screws to the stand for an LG lcd flatscreen model
AnonymousApr 09, 2009
ii have a 42in philips and lost the screws for the tv stand .... any idea wat size i might need ?? ii have a 42in philips and lost the screws for the tv stand .... any idea wat size i might need ??
I have the same problem! My Insignia LCD 37 inch was mounted, but now I want to use the stand but can't find screws! Help!I have the same problem! My Insignia LCD 37 inch was mounted, but now I want to use the stand but can't find screws! Help!
AnonymousMar 15, 2014
Ineed the screw for my sony tv so i can put it on my tv stand my tv is a 40 inIneed the screw for my sony tv so i can put it on my tv stand my tv is a 40 in
AnonymousMar 16, 2014
I have lost all the screws for my CY-SMC1000d tv stand when moving,what screws do I needI have lost all the screws for my CY-SMC1000d tv stand when moving,what screws do I need
AnonymousMar 23, 2014
I need to attach my tv to the stand that it came with..not a wall mount, just the stand and I need to know the screw sizeI need to attach my tv to the stand that it came with..not a wall mount, just the stand and I need to know the screw size
AnonymousMar 27, 2014
Trying to take the back part off of a Cosby 32 inch tvTrying to take the back part off of a Cosby 32 inch tv
You can't post conmments that contain an email address.
This information was found on the insignia website www.insignia-products.com under technical information for the insignia television model :42"1080p NS-LCD42HD.
CableVision UR2-CBL-CV04
code: 096
Charter DIGITAL
code: 0463
Comcast M1057
code: 0463, 10463
Cox COX
code: 0463
Direct TV RC23
code: 10463
Dish Network VIP508
code: 720
Dish Network VIP622
code: 720
Motorola DRC800
code: 0463
One for All URC-6690
code: 0464
Phillips PDVR8
code: 115
Phillips PH5DSS
code: 115
Phillips PH5DVD5
code: 115
Phillips PMDVR8
code: 115
RCA RCU807
code: 135
Sony RM-VL600
code: 8043
TiVo HD
code: 0091
TiVo SERIES 3
code: 0091
I am also having a problem with my Insignia NS-LCD42HD-09. When I turn it on it is distorted and ghostly. It usually clears up within 10 minutes, but it can revert back at anytime. The television will be 3 year old this December. Does anyone have any advice (other than calling the Geek Squad)
Your probably having what cable guys call a SNR ( signal to noise ) issue. There's no way to know unless you call your cable provider. The SNR should be 32 and above with zero pre/post errors. In case you want to ask the tech what they are.
The TV is very low Grade considered a cheap china knockoff and the panel has gone bad as expected you need t replace the TV and next time steer clear of the non brand products (aka walmart)
As for the part number... not sure. But you can purchase a new remote here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=NS-LCD42HD-09&uuid=12749564580310
Look up both Tv's model numbers on the internet and you should be able to find a manual for each. Look at the part numbers in the manuals for each stand and see if they are the same. I'm guessing they are different but you might get lucky.
At least the 5VDC stand by power supply is working, there will be a control signal pin from the mainboard to the power supply board to turn on the rest of the power supplies (24vdc for the back light inverter boards, 12vdc for other circuits). Any bulging caps in the power supply?
