Is the machine with auto drain?
Most dishwashers kick on a valve to fill with water.
There's a float in there somewhere that triggers the shut off to the filling water.
Once water reaches this cut off level the pump should be throwing water thru the wash arms.
If base isn't filling to capacity...Id look to the drain valve.
If it fills to capacity and stops...the pump may be out or something is obstructing it.
Hope this helps...
