No it's either the stylus or the pressure to the stylus is not enough. The weight at the end of the arm will increase the pressure on the stylus. Turn it up in slightly testing a record till the stylus tracks in the grooves. The trick is to get it so that it stays in the groove without creating a rumble sound. Remember though a worn stylus will not track at all.
Most cartridges track at 2 to 3 grams. If the Weight on the arm has numbers they will correspond to the weight in grams. If you have to raise it very high the stylus is too worn.
