STANDARD TYPE GM ROD BOLTS
STAGE 1---18 LB/FT (GRAPHITE GREASE UNDER HEAD, OIL THREADS)
STAGE 2---30 DEG's additional bolt head rotation.
CRANK BOLT
GRAPHITE GREASE UNDER HEAD & WASHER, OIL THREAD
STAGE 1---70 LB/FT
STAGE 3---15 DEG's additional bolt head rotation.
CYLINDER HEAD BOLTS for standard gaskets
GRAPHITE GREASE UNDER HEADS & WASHERS, OIL THREADS
SEE SEPARATE SHEET FOR TIGHTNING SEQUENCE
STAGE 1---18 LB/FT 25NM
STAGE 2---90 DEG's additional bolt head rotation.
STAGE 3---90 DEG's additional bolt head rotation.
STAGE 4---90 DEG's additional bolt head rotation.
STAGE 5---45 DEG's additional bolt head rotation.
For leaking head gasket it has to be replaced. For head gasket
leaking and other troubleshooting, there are help links provided. Its suggested
to click the link below and go through the troubleshooting procedure to confirm
the issue :-----Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
-----------Water in engine oil? http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
-----------How to replace head gasket on car?http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-head-gasket-on-1994.html-------------How to know what is faulty Cylinder head or Head gasket?http://schematicsdiagram.blogspot.com/2011/12/how-to-know-what-is-faulty-cylinder.html
-------------- Can I just replace Head Gasket on 1991 Buick Century?http://schematicsdiagram.blogspot.com/2011/12/can-i-just-replace-head-gasket-on-1991.html Location of Head Gasket ?
http://schematicsdiagram.blogspot.com/2011/12/location-of-head-gasket-on-1994-grand.html
HOW TO REPLACE A HEAD GASKET
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-head-gasket.html
How to replace Exhaust Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-exhaust-manifold-on.html
How to replace Intake Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-intake-manifold-on-acura.html
How to replace Cylinder Head ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cylinder-head-on-acura.html
Is it Easy to replace head gasket?
http://schematicsdiagram.blogspot.com/2011/12/is-it-easy-to-replace-head-gasket-on.html
Should I only replace head gaskets or complete head gasket
assembly?http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
This will help. Thanks.
For leaking head gasket it has to be replaced.For head gasket leaking and other troubleshooting,there are help links provided.Its suggested to click the link below and go through the troubleshooting procedure to confirm the issue :-----Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
Should I only replace head gaskets or complete head gasket assembly?http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
---------This will help.Thanks.
