SOURCE: Yamaha WR250F Leaking coolant
yes thats the weep hole it leaks when your water pump iner seal starts going bad,
SOURCE: yamaha yz 125 2001.water leak
Yes, the water seal is leaking. This is the indicator hole for the water and oil seal.
Enjoy the ride !
Jon
It means your water pump seal is seeping at this point. Eminent failureportended. Replace water pump. Seals on pumps usually fail because of bearing wear, so this is a precursor to pump shaft failure. Good luck
SOURCE: Kawasaki KX250F 2006 model coolent leak
There are two seals on the impeller pump. Replace the seals an the leak is stopped. Put in a new cover gasket as well.
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx Click on the "ENGINE COVERS" tab.
A “very helpful” rating for this answer? Thanks!
