Now, let's clean your system up a bit.
Click Start/Programs and look for the RUN command. You might see it anywhere
once you click Programs, or it might be inside the Accessories folder.
Click RUN and when it opens up type "msconfig.exe" (without the
quotes) then hit ok.
When the System Configuration window opens click the Startup tab. In the
Startup Tab we are only concerned with 2 columns, the first column which is the
Startup Items and the column that says Command. You can put your mouse pointer
between two column headings and it will turn into a +, then hold the left mouse
button and drag the column over to the right to expand it so you can read
what's below it.
Now everything has a check mark beside it. This means that everytime you
start your computer, these items have to load and run. Most of the stuff
is good, but there might be so viruses that are running also so we want to
remove the check mark from them.
Start with the first time listed under the startup item column and look at it
and look at the command for it. Most times you will see something under
the command such as Adobe, Yahoo, Dell, HP, etc. that you know are ok so go to
the next item. Also if you see something under the command like C:\Program
Files\.... then it's ok, also C:\Windows\System32\.... then it's ok.
If you see something that does not have anything under the Command column,
remove the check mark, it's a virus that's trying to hide.
If you see something that says something like: dumprep 0 -k in the startup item
column remove the check mark from it.
Reboot machine.
Most viruses will attach themselves to a User Account and be in one of the
hidden folders. If you see something under the Startup Item column that
does not make sense such as xjieryert67 or 12326543;ehdyu and when you look at
the Command column it is located in c:\Documents and Settings\the user id\Local
Settings\Application Data\...... remove the check mark because it's a
virus. Note that the user id will be the name of one of your user
accounts. It could be something like your name, Owner, User, etc.
When you have been through all the items click OK or Apply then OK and
the system will show you restart options. Select Exit Without Restart so
that the machine does not reboot yet.
Don't be afraid about removing the check mark from something. All this
does is stop something from starting when you boot your machine. You can
always go back in and put the check mark back on something.
Now all we've done so far is stopped the virus from running when you boot your
machine. The next thing we want to do is kill it.
Open your internet browser and go to www.google.com and in the search box type:
'Download Cnet Malwarebytes" (without the quotes) and you will see a site
called download.cnet/malwarebytes. Download and install MalwareBytes from
that site. When their site opens be sure to click on the Green Download
button on the left, that's malwarebytes. Don't click the Red Download
button, that's some junk.
Once malwarebytes is at the end of the installation process it will pop up the
Gui Interface and a popup window overlaying it that says Decline or Accept a 30
Day Trial. CLICK DECLINE and your copy will always be FREE without a
trial period. Then take the option to RUN A QUICK SCAN.
The Quick Scan will run and if it finds infections the number will be shown in
RED. When it is done you will click SHOW RESULTS. A notepad text document
will open up showing you the results of the scan. You can close it
because we are only interested in the Gui Interface. Next click REMOVE
SELECTED RESULTS and the results will already be selected for you. Once
the infections are removed you will be instructed to click and reboot your
computer.
If you're amazed at how many infections Norton or McAfee let in give them the
boot and go with a FREE Antivirus such as Microsoft Security Essentials, AVG
Antivirus or AVAST Antivirus. If you're going to get a virus, WHY PAY FOR
IT WHEN YOU CAN GET ONE FREE.
Also when you reboot and everything is running smoothly go into www.google.com
and search for "download Mozilla Firefox", and "Download
Opera" and "Download Google Chrome". Download and install
each of these internet browsers, you don't need to make them your default
browser unless you want to. They are much faster and safer than Internet
Explorer. if you want a virus, continue using Internet Explorer. And
don't worry they don't take a long time to install like Internet Explorer they
install very fast.
More little things that makes your system run faster:
Don't install toolbars from everybody that wants to stick it on your internet
browser. You only need Google and Yahoo toolbars. Toolbars will
clutter your browser and slow it down and some just let viruses, addware and
spyware in.
Be careful when you search the internet and download something because some
products like Norton, McAfee and Ask will already have a check mark by them to
install on your system. You don't need that junk.
Click Start/Program and look in your program list and uninstall any buggy and
junk programs such as: Weather Bug, anything from Freeze.com, My Fun Web
Products, My Web Search, Coupons, Rebates, Norton Products, McAfee Products,
etc.
Sometimes there will not be an uninstall option for Norton or McAfee. In
that case click Start/Control Panel/Add or Remove Programs in windows XP. For Vista
click Start/Control Panel/Programs and Features. When the window opens
showing you all the installed programs, click to highlight the one you want to
remove and click uninstall, on some it might say remove.
Most people rely on Norton and McAfee because that is what they have on their
job. On the Job, they have what is called the Enterprise Version of
Norton or McAfee, plus they have someone there monitoring it all the
time. The Enterprise Version is a good product, but what they sell you
and I in the store is the consumer version which is nothing but a core hog and
junk. Also now since they realize people are gaining knowledge about the
products they give it away Free from your Internet Service Provider. Also
remember this, on your job you're on lock down. You can't go to certain
sites, you can't get to your personal email, etc. So that help protect the
company from getting viruses. At home there are no restrictions unless
you're smart enough to set them.
