Sony KV-XJ29M50 29" TV Logo
Anonymous Posted on Jul 29, 2011
Where is the vertical part of the Sony KV-XJ29M50, or what type of IC in that part?
Level 3:
  • Sony Master 17,130 Answers
  • Posted on Jul 29, 2011
Sony Master
Level 3:
Answers
17130
Questions
0
Helped
3634417
Points
52372
The easiest way to identify the Vertical drive IC is to trace the horizontal Yoke coils to the board, the vertical coils to the board must lead to the vertical drive output where the IC is seen normally a inline IC with a heat sink.
Check if the solder joints are weak if so solder and check.
Sony KV-XJ29M50 29
vertical setting solution
CAN WE CONNECT EXTERNAL SPEAKERS TO SONY KV-XJ29M50 TV
Check whether there is an audio out RCA type sockets at the rear side of the TVm marked as Audio Out. If so, you can connect these sockets to any exterenal audio amplifier, by connecting Av cable in between devices, and can listen audio from external speakers. Picture of AV cable is shown. Keep free its yellow pins. Use red and white.
1helpful
2answers
Sony KV-XJ29M50 top half vertical problem i.e shrink
Check and replace all electrolytic capacitors at its vertical output section. There will be 5 or 6 numbers. Replace all of them at the same time.
1helpful
Hello
Vertical output Ic is in the A board itsef. It is an SIL type [Single In Line type] Ic, screwed onto a metal heatsink to radiate heat out of it while working.
OK.
Dimana letak bagian vertikal dari Sony KV-XJ29M50, atau apa tipe IC di bagian itu ?
halo
Output IC vertikal dari himpunan ini dapat terletak di A dewan itu sendiri. Ini adalah SMD [Permukaan Gunung Tipe] ic, mengacaukan ke heatsink meatus untuk memancarkan panas dari itu saat bekerja. OK
1helpful
Kv-36xbr800
Hiii...
My version is :
For safety reason you should replaced them ( Horizontal ic,Vertical ic, Deflection ic) and olso all the big capasitor nearest the ic....that's my version....if you have big budget for it....he..he....
Thank's
[Vrya]
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
