Cole, The cut you are describing is challenging, but possible on a 20" scroll saw. First the blade--- you call this a hollow plank. If this is something like a hollow-core door, then the 1.5" thickness will be no problem. If you have to cut through a solid 1.5" (as you would at the edge) then you have a slow go of it unless you can find a pretty coarse pitch blade (big teeth). Second, making the turn----- assuming you are making this cut somewhere near the center of the 5' lenghth, then you won't be able to simply make a 90 degree turn after you cut the initial 5 inches. But you can make an approximately 60 degree turn, then stop the saw, leave the workpiece in place with the blade still in the cut, and reset the blade to cut sideways (so that the teeth of the blade are facing to your left or right rather than pointing toward you.) Before you make this blade turn, however, you should make the other 5 inch cut, so that you don't have to make the blade turn twice. Alternatively, if the 5 x 1.5 piece you are removing is just scrap, then you can make your two 5 inch cuts just converge to a point at the middle of the 1.5 inch line so that you can remove most of the scrap without moving the blade. Then you can reset the blade more easily with the workpiece removed from the saw. I hope you found this helpful.---- Oh, one more thing! The 1.5 inch part of the cut would be a lot easier simply by using a coping saw - they are about $15. Actually, you could do the whole cut with a coping saw. Good luck! Al K
Your planer is equipped with a turret stop (M), shown in
Figure 11, for repetitive planing of pre-set depths. Stops are
set at 0", 1/4", 1/2" and 3/4". Use the 0" setting when planing
between 1/8" and 1/4".
TO SET A PLANING DEPTH
1. Be sure the carriage is set above 1-1/4" before trying to
set the turret stop.
2. Turn the turret stop until the desired measurement
shows (Fig. 11).
3. Unlock the head lock lever (Fig. 8). Turn the depth
adjustment crank, lowering the carriage by the desired
increments, until it contacts the turret stop.
NOTE: DO NOT USE FORCE TO CRANK THE CARRIAGE
BELOW THE LEVEL THAT THE TURRET STOP INDICATES.
PERMANENT DAMAGE TO THE HEIGHT
ADJUSTMENT SYSTEM ON YOUR PLANER WILL
RESULT.
NOTE: The 3/4" turret stop can be adjusted for other planing
thicknesses. Adjusting the 3/4" turret stop does not affect the
other turret stop settings.
TO ADJUST THE 3/4" STOP FOR OTHER
THICKNESSES
1. Unlock the head lock lever (Fig. 8) and turn the adjustment
handle counterclockwise to raise the cutter head.
2. From the back of the tool, locate the turret adjustment
bolt (N) shown in Figure 11. This bolt is set for a 3/4"
depth of cut at the factory. Use the crescent wrench provided
to loosen the jam nut. Adjust the bolt up or down to
reach the desired planing depth.
3. Turn the depth adjustment crank, lowering the carriage by
the desired increments, until it contacts the turret stop.
Hope this helps.
