Garden Logo
Posted on Jul 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Noma/Dynamark/Riding Mower/M0del#E3912030 Ser#S001219331405 C0de1335 I w0uld like t0 ha ve a manual sh0wing parts and the way they are assembeled.Expl0ded veiw diagram w0rks als0.Trying t,o remove the right rear wheel. Removed E-clip on end of axle and two flat washers behind E-clip.Afraid to get to rough with it not knowing if somthing else needs to be taken loose.If I had a manual or diagram I would know.Please advise.
Anthony Browning
Level 3:
  • Mtd Master 640 Answers
  • Posted on Jul 29, 2011
Anthony Browning
Mtd Master
Level 3:
Answers
640
Questions
Helped
189021
Points
1779
After the E-clip is removed and the washers slide off the wheel should slide off. This being a rear wheel it has to come straight off due to the key. Nothing else holds the wheel on. If it is not just sliding off, it is okay to use a little force to pull it off.
I hope this helps.
Operators manual for 84 Dynamark 4218
Randall, diagram for deck belt routing, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
http://www.ssbtractor.com/wwwboard/messages8
lawn tractor belt routing Google Search
Belt Routing Charts for Lawn Mower Decks Canada
Jul 25, 2016 • Garden
Down load manual for dynamark riding mower 12/39
try: http://www.manualslib.com/
Mar 06, 2015 • Garden
2helpful
Dynamark / Noma riding mower Mod# A38120910, SER# 149606, Code 0025M. how to get rear tires off?
i change the tires with the wheel on the mower if they don't slide off with the bolt or clip removed
Jul 02, 2012 • Garden
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
