We have a Kenmore Self Cleaning electric stove/oven model #C970-655632. The stove top works fine. The Oven will not turn on. The clock does not turn on. We have changed the fuse and the starter for the flourescent lighting. This did not fix anything.
In repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
I have a Kenmore model 66595824003 with the same problem. Stovetop works, but not the oven. Electrical display doesn;t work either.
The control panel flashes F11
Stove is14 33 754. Downdraft.
I have a kenmore Glass top self cleaning oven, the temp in the oven never goes passed 200. All the burners on the stove top work fine its just the oven that will not heat up
The light no longer lights up the LED clock/programming any suggestions?
