Just bought Zire 31 and won't hot sync Outlook Calendar, Contacts, Notes with the following log:
OtSync operation started
- Installed file: C:\Program Files\Handspring\MC\Install\dbscan.prc
OK Install
Outlook Notes
The conduits were unable to attach to Outlook, possibly because the logon was canceled or otherwise failed.
Synchronization failed.
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
OK Outlook Notes with 1 message(s)
Outlook Calendar
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
OK Outlook Calendar
Outlook Contacts
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
OK Outlook Contacts
Outlook Tasks
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
OK Outlook Tasks
OK Expense
OK Note Pad
OK Quick Install
-- Backing up db psysLaunchDB to file C:\Program Files\Handspring\MC\Backup\psysLaunchDB.PDB
-- Backing up db Saved Preferences to file C:\Program Files\Handspring\MC\Backup\Saved_Preferences.PRC
OK System
HotSync operation complete
Outlook Notes
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
Outlook Calendar
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
OK Outlook Calendar
Outlook Contacts
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
OK Outlook Contacts
Outlook Tasks
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
Outlook Notes
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
Outlook Calendar
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
OK Outlook Calendar
Outlook Contacts
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
OK Outlook Contacts
Outlook Tasks
OLERR:0C-000F (0x0)
OLERR:0D-0003
OLERR:0D-0001
- Not Synchronized
OK Expense
-- Outlook Calendar
User: Christina M. Carlos
Version: 3.0.2 (Build: 20010112)
ERROR: 00004011
Error connecting to Outlook.
685: BaseConduit
ERROR: 00004011
Root folder open failed.
12883: BaseConduit
Also, When I started sync, a Windows Messaging message came up,
"MAPI spooler could not be started. Close then re-start all mail-enabled applications. MAPI 1.0 [000004C7].
Tried a dB Scan and it said insufficient memory to scan unique ids and did not complete scan
IS THIS A PALM ISSUE OR AN OUTLOOK ISSUE?
Re: Just bought Zire 31 and won't hot sync Outlook...
Outlook which offers an inconceivable response for customers. There are such enormous quantities of enhanced features open which to an extensive degree helps in making work more straightforward and informing smooth. This is a champion among different things by Microsoft and it is shown up to increase pleasant correspondence of customers as it is furthermore redesigned with the outrageous interface and easy to use features.
Website: https://www.contactxpert.com/outlook-customer-service.html
Cotactxpert Outlook Customer Service Number Offers 24 7 Support For Your Outlook Account By Contacting Outlook Phone Number You may get resolve your outlook account by the help of...
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
You can sync to Outlook on the PC and then get the Outlook data onto
the iTouch. If you have a newer PDA, It's install CD has a Sync options menu item
where you can switch between Palm Desktop and Outlook. If you no longer
have the original install CD or have an older device Pocket, Copy from
Chapura.com It will move the Palm Desktop records to Outlook.
In my LifeDrive, my VersaMail set-up wasn't quite right. I had my e-mail address in as "name", rather than "[email protected]".
That fixed MY problem.
Others (including me) are having trouble keeping the HotSync set to sync Calendar. It keeps going back to "Do Nothing"
Go to HotSync in the system tray on your PC, right click, select Custom and see if your Calendar (conduit) is set to 'Do Nothing' as an action. I was able to get it to change and work, but just once (so far!!)
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it.
Here is what I did to resolve sync errors:
1. Perform a hard reset on the Palm
2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old.
3. Connect the Treo to your computer.
4. Right click the Hotsync icon in the taskbar and click Custom.
Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld.
5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
I was having the same problem, and I used Detect and Repair in Outlook. Now all is working fine. You will need the original CD that you installed from.
Hope this helps as none of the other things that I saw on any sites did until I tried this.
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
Tryy this -- Go to Chapura.com and purchase the pocket mirror software. I have Sprint service and that additional software has resolved my synch issues.
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
