Question about Dell Inspiron 700M Notebook
Just had a thunderstorm last night. My Dell Inspiron 700m was connected to a Triplett Power Strip. Other devices connected to the power strip seem to be working. When I put the power supply plug in the side a green light flashes on the top rear. When I press the on-off button the Inspiron does not startup. Did it get fried? Is there a fuse I can check? If so were is the fuse located? Are there other things I should check for?
    Genius:
  • 1,288 Answers
Hi
Normally the AC adaptor gets fried, the fuse inside the plug that goes into the mains normally blows. If you are getting power to the laptop in some form, you should first of all check the adapter.
Plug this into the mains and, with a multimeter set to 20 volts DC place the red probe onto the inner jack pin, and the black probe to the outer part of the jack, see if the voltage reading is 20 volts, give or take a volt. ONLY do this if you have first inspected the charger, check for any burning smell or melting of the case or wires (to be safe).
If the voltage is correct, (remember that dell laptops will only charge with genuine Dell chargers), the charger may be powering the laptop but NOT charging it..If you can, try and obtain another Dell charger to eliminate the charger being at fault.
Now remove the battery, press and hod the power button for 30 seconds and try it on ac power alone, a fried battery will sometimes stop the laptop from booting, if it DOES boot, the battery has been damaged (possibly the battery charge circuit too).
If it does NOT boot, the problem lies on the motherboard. There is, near the charger port on the motherboard a small ceramic fuse of about 3mm length with metal caps. This may look intact but if again, you apply a multimeter set to 10 Ohms across the terminals of the fuse and do not get a reading, the fuse is dead and will need replaced. I normally bridge the fuse connections with a soldered wire of 3 amps but this is NOT a recommended fix long term
If the laptop still does not boot, there is a resistor or possibly a capacitor blown, remove the motherboard fully and check , you will see a blown resistor as it will appear charred and blackened, whilst capacitors tend to burst at the top (usually).
In this case, it is probably not worth the cost of fixing.
If the laptop does boot, but does not charge even with a new charger, look at the motherboard again, near the battery I THINK there is a similar ceramic fuse for the battery charging circuit, check this also
Posted on Jul 28, 2011
Testimonial: "Thank you for your comprehensive diagnosis. I will check it our and get back to you"
    President:
  • 3,278 Answers
Hello.
Thiere is no fuse to replace, unlike some other devices you may be familiar with.
However, there are many components that could be affected, such as the motherboard, CPU, and battery.
Disconnect the power adapter, flip over the laptop and remove the battery. Reconnect the power adapter and see if the laptop powers on. If it does, replace your battery. If it does not power on have your laptop checked. Could be a fried motherboard.
Hope this helps.
  • graeme ian hunter Jul 29, 2011
    "my guess is that the inline ceramic DC
    fuse is open. This is a small oblong block be 1/4 inch long, 1/8
    inch high and wide, surface mounted very near the AC adapter jack.
    This can be bypassed with a suitable Picofuse, be 8 amps, soldered across the conductive ends of the existing fuse case.
6ya staff
SOURCE:
My dell inspiron 700m inspiron screen cracked so I replaced it. I purchased the new one from Laptop LCD panels (Dell Inspiron 700M 12.1 Inch Glossy 1280 x 800 Laptop Lcd Screen) to connect it I used the...
The flat cable simply trasfers visual data to the screen to be displayed. The power for the backlight comes through the inverter which takes the low voltage DC power and converts it to high voltage AC power for the backlight. I am not sure what the usual thermal range is for that cable. Just make sure that all connections are tight. Loose connections can cause thermal conditions and shorten the life of all the components. If that flat cable was bad in any way, it most likely would not even carry a signal.
Nov 29, 2009 | Dell Inspiron 700M Notebook
Dell inspiron 700m wont power up
Which way do you power up the laptop?
The AC power or laptop battery?
If the AC power, you should check the wire is connected well.
If the battery, you should check whether the battery is charged full.Maybe the battery is aging, you need to get a new Dell inspiron 700m battery.
You can get a replacement at shop-batteries.com
Aug 26, 2009 | Dell Computers & Internet
Fan running and in power save mode
If you are connected to a power strip, reset the power strip. Also, connect an external monitor to see if the display is the problem. Good luck.
Jun 13, 2009 | Dell Inspiron 530 Desktop Computer
COMPAQ Presario v6000 dead, Period
Hi there.
Remove the battery and try it on AC power only, if it boots up turn it back off and put the battery back in again and power it up again, if it boots up, the cause will have a small surge from the power strip caused by the thunder storm.
Good luck and thanks for using Fixya!!
Feb 27, 2009 | Dell Latitude L400 Notebook
Power button mulfunction?
ok, to get at the switch board, take a flat bladed screwdriver and /carefully/ lever the outside ends of the hinge covers vertically upwards. Once the covers are free (you'll find that they are attached to the blue strip), slide the blue strip and hinge covers to the LEFT and then lift. The strip should free from the chassis. The switch board should be held in by two screws (one holds a lug to hold down the keyboard) and connects to the motherboard via a ribbon cable. The part number for the switch board is printed on the upper side of the board. You might find it advantageous to order a new ribbon cable as well; both parts should be readily available from your newarest independent service centre or direct from Dell.
Oct 20, 2008 | Dell Inspiron 5100 Notebook
Dell Inspiron 700m
I have a Dell Inspiron 5100. I've had it for about three years. One day it did the same thing, no power, no fan, nothing. I replaced the power supply with a 350 watt unit from Office Max. I spent about $40 and I'm using my Dell to send you this response.
Jul 22, 2008 | Computers & Internet
How to replace Dell 700m power pin
You must remove the keyboard bezel and the keyboard to get to the system board. Follow this link for disassembly instructions. Thanks //D
http://support.dell.com/support/edocs/systems/ins700m/en/SM/index.htm
Apr 28, 2008 | Dell Inspiron 700M Notebook
Dell Inspiron 700M Notebook Logo
289 people viewed this question
Ekse
Clive
Clive
Alun Cox
