Cars & Trucks Logo
Posted on Jul 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On my 2000 Golf 1.9 tdi ALL vacuum hoses are disconnected. How do i connect the hoses between the turo boost control valve and the egr solenoid valve as well as the main vacuum hose from the vacuum pump. I also need to know where the hose from the turbo waste gate actuator goes in. I have fitted a brand new turbo but the car is VERY sluggish with no boost at all and it reaches about 90 km/h flat out
Richard Darley
Level 2:
New Friend:
  • Expert 90 Answers
  • Posted on Jul 28, 2011
Richard Darley
Expert
Level 2:
New Friend:
Answers
90
Questions
Helped
33644
Points
170
You will need a Vacuum hose diagram to hook thes up correctly. There should be a diagram on the hood or raiator cover of the vehicle. If the diagram is missing you will have to take ALL info from your car (Year,Make, Model, Engine size, Engine code) and obtain the diagram from a dealer.
Hi I've got a golf 2.0 tdi, when on motorway I get loss of power when turn engine off and start back up it can be fine for bit then happens again. Any ideas?
In your case the turbocharger is responsible for engine losing power.
The car goes in "limp home" mode!!!
After scanning the EDC engine control module with a VAS, VAG-Com or KTS -BOSCH diagnosis tool you will find this: Fault code: P1557 - Charge pressure control. Value above upper control limit static, (Turbo Boost pressure control exceeded).
1. Engine stopped and ignition switched off. Check all pneumatic connections and hoses between turbocharger actuator = pressure unit for boost-pressure control, boost-pressure control solenoid valve, vacuum reservoir, EGR control solenoid valve, intake-manifold flap solenoid valve, EGR valve with throttle - part of intake manifold. Also the vacuum connection between tandem pump and brake booster. If you find something wrong replace parts. If not go to step 2.
2. Extract the hose of the turbocharger actuator = pressure unit for boost-pressure control part of turbocharger. Instead of the original hose you must place another 1 meter long hose with the same inside diameter, and then you check to inspire yourself the air from the other one extremity of this hose. The mechanical connecting rod of the turbocharger actuator must have a smooth and whole motion. If you can do that with your mouth, then you must replace the boost-pressure control solenoid valve. If you can not reach this with your mouth, then you go to step 3.
3. This is the most difficult work. The problem is that the soot particles deposits inside the turbocharger plugging the variable nozzle geometry mechanism = adjustable vanes of the turbine. If the turbocharger actuator is not able to adjusts the turbine vanes, the charge air pressure increase too much and ECM (Engine Control Module) goes in "limp mode" = engine protection software. As a result the "limp home" mode engine still runnings until you turn the engine off (ignition switch off) and back on, when the "limp mode" is deactivated, but the fault still remain in ECM memory!
4. You must be able to extract the turbo from the engine and then to disassemble the turbocharger, clean inside adjustable vanes mechanism and refit all.
tip
How to fix "limp mode" on Audi TDI
If the car goes in "limp mode"!!!
After scan the EDC-15P engine control unit with a VAG or KTS -BOSCH diagnosis tool you will find this: Fault code: P1557-Turbo Boost pressure control exceeded
1. Engine stopped and ignition switch off. Check all pneumatic connections and hoses between turbocharger actuator = pressure unit for boost-pressure control, boost-pressure control solenoid valve, vacuum reservoir, EGR control solenoid valve, intake-manifold flap solenoid valve, EGR valve with throttle - part of intake manifold. Also the vacuum connection between tandem pump and brake booster. If you find something wrong replace parts. If not go to step 2.
3. This is the most difficult work. The problem is that the soot particles deposits inside the turbocharger plugging the variable nozzle geometry mechanism = adjustable vanes of the turbine. If the turbocharger actuator is not able to adjust the turbine vanes the charge air pressure increase too much and ECU (engine control unit) go in "limp mode" = engine protection software. As a result the "limp mode" engine still running until you turn the engine off (ignition switch off) and back on when the "limp mode" is deactivated, but the fault still remain in ECU memory!
on Dec 04, 2009 • Audi A4 Cars & Trucks
Iv been told that there is a valve that sticks somewhere around the turbo on my A4 tdi could anyone tell me exactly where it is and how to get it out?
The boost-pressure control solenoid valve is placed in front right side of the cylinder block. Follow the rubber vacuum pipe direction, going from the turbocharger actuator toward the boost-pressure control solenoid valve.
1helpful
Runs along fine then looses power but if you shut it off and restart its fine again
Your car goes in "limp mode"!!!
3. This is the most difficult work. The problem is that the soot particles deposits inside the turbocharger plugging the variable nozzle geometry mechanism = adjustable vanes of the turbine. If the turbocharger actuator is not able to adjust the turbine vanes the charge air pressure increases too much and ECU (engine control unit) goes in "limp mode" = engine protection software. As a result the "limp mode" engine still running until you turn the engine off (ignition switch off) and back on when the "limp mode" is deactivated, but the fault still remains in ECU memory!
Car lost power and speed
For VW Golf TDI:
After scan the EDC-15P engine control module with a VAG-COM or BOSCH KTS diagnostic tool connected to the data link connector of the car, (placed on central console under A/C controls behind a plastic cover), you will find this: Fault code: P1557-Turbo Boost pressure control exceeded
3. This is the most difficult work. The problem is that the soot particles deposits inside the turbocharger plugging the variable nozzle geometry mechanism = adjustable vanes of the turbine. If the turbocharger actuator is not able to adjust the turbine vanes the charge air pressure increase too much and ECM (engine control module) go in "limp mode" = engine protection software. As a result the "limp mode" engine still running until you turn the engine off (ignition switch off) and back on when the "limp mode" is deactivated, but the fault still remain in ECM memory!
3helpful
2answers
1999 tdi 1.9L eci code p1550. loss of power on hills
Its not your clutch. Its one of three things which is regards to your turbo.
17958/P1550/005456 - Boost Pressure Controle Valve (N75): Control Deviation
Possible Symptoms
  • Irregular behaviour
  • Reduced power output
  • Limp mode
Possible Causes
  • Hoses/Pipes incorrect connected, disconnected, blocked or leaking
  • Charger Pressure Control defective
    • Solenoid Valve for Boost Pressure Control (N75) defective
  • Turbocharger defective
Possible Solutions
  • Check Hoses/Pipes to/between Components
  • Check Charge Pressure Control
    • Check Solenoid Valve for Boost Pressure Control (N75)
  • Check turbocharger
8helpful
2answers
Dtc p1550 1999 vw tdi intermittent poor power.
For VW TDI: Fault code P1550 = "Charge Pressure Deviation"
You must check up all vacuum hoses, the pressure charge air line (pressure hoses, spring-type clips, charge air cooler), the vacuum reservoir and also all solenoid control valves.
You must try follows if you are able to do this:
3. This is the most difficult work. The problem is that the soot particles deposits inside the turbocharger plugging the variable nozzle geometry mechanism = adjustable vanes of the turbine. If the turbocharger actuator is not able to adjust the turbine vanes the charge air pressure increase too much and ECU (engine control unit) go in "limp mode" = engine protection software. As a result the "limp mode" engine still running until you turn the engine off (ignition switch off) and back on when the "limp mode" is deactivated.
It is some work to do here, but after that you will be full satisfied!
I have a 2003 jetta TDI with 150,000 milea, within the last few weeks the engine sputter when it goes up hills, it looses power, and there is dark black exhaust comming from the tailpipe. Alan Hutchings
If you scan the EDC-15P engine control unit with a VAG or KTS -BOSCH diagnosis tool you will find this:
"Fault code: P1557 - Turbo Boost pressure control exceeded"
3. This is the most difficult work. The problem is that the soot particles deposits inside the turbocharger plugging the variable nozzle geometry mechanism = adjustable vanes of the turbine. If the turbocharger actuator is not able to adjust the turbine vanes the charge air pressure increase too much and ECU (engine control unit) go in "limp mode" = engine protection software. As a result the "limp mode" engine still running until you turn the engine off (ignition switch off) and back on when the "limp mode" is deactivated, but the fault ("Fault code: P1557 - Turbo Boost pressure control exceeded") still remain in ECU memory !!!
It is some work to do here, but after that you will be full satisfied! NO MORE "LIMP MODE"!!!
2helpful
Vw caddy 2001 TDI
5helpful
2answers
Audi a4 1.9tdi
It is a certified solution. Last year in July I made this turbocharger cleaning on my car - 2000 Audi A4 1.9 TDI 116 HP. After 25000 km my car runs like an authentic AUDI 1.9 TDI.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
