Plug the USB cord from the camera into the USB port on your computer. The computer should see the camera as an external storage device. You can then click on the storage device and open the folder and copy the photos to your computer. ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
If you have your original Windows repair disk, run a repair installation, (**Not a reinstall and don't reformat, just a repair) this should be an easy way to fix your problem, taking maybe an hour.
I have had this problem with Canon cameras, it seems to be a bug in their software. What make and model is your camera?
My solution was to manually open the camera transfer software, and manually select all images for download (rather than using "download all").
Another option is to put the memory card into a card reader and copy the files across as if you were copying them off a USB memory stick. You might have to rotate the pictures manually if you do this and use the camera in portrait format, however. Using a card reader will avoid running your camera batteries down, and will speed up downloads to boot!
