SOURCE: spindles will not turn
There is a rubber drive belt that needs to be replaced, Panasonic part RDV101YA. This place says they have them:
http://www.partstore.com/Model/Matsushita/Panasonic/RR930.aspx?ModelAliasNumber=rr-930
I've never had to work on one of these so I can't say exactly what you might have to remove to get to the old belt and pulleys it rides on. But it's usually not too bad of a job to change a belt.
SOURCE: Microcassette Transcriber M-2000 will not
Hello I recomend to send you unit to service Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem or maybe another is to get a refurbished unit http://www.tvps.com/Products/Sony-M-2000-Micro-Cassette-Transcriber-In-Box---Factory-Refurbished__SO-P-M-2000-Box.aspx
SOURCE: how do I erase tape on sony microcassett
Hold down the 'Erase' button and press the 'Rewind' button. It will erase the tapes as it rewinds.
SOURCE: I have a new Sony
Hello sorry the M-2000 don't have the ERASE feature but your only option is to get a tape eraser you can get one at http://www.tvps.com/Products/ECS-ME20-Mini--Micro-Cassette-Eraser---New__VE-ME-20.aspx just think positive your unit will last longer the eraser prolong the life of units just pass the microcassete once on the eraser and is done full erase :)
SOURCE: have a panasonic RR930 microcassette
If neither rewind nor backspace work, the common problem would be that the solenoid grease has dried up and the solenoid is not retracting all the way. However, the track that the mechanism moves in also wears out, as well as the plastic rocker that depresses the rewind button where it engages the metal slide.
If backspace works but not rewind from the pedal then the problem is the pedal.
