Acer Aspire™ T180 PC Desktop Logo
Posted on Jul 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tower will not power "on" I shut-down the
Vincent G
Level 3:
  • Master 2,363 Answers
  • Posted on Jul 28, 2011
Vincent G
Master
Level 3:
Answers
2363
Questions
Helped
1032970
Points
5917
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Computer won't turn on after trying to plug in
You never plug anything into the expansion slot whilr the computer is turned on and running. This is a sure way of damaging the motherboard.
Turn off the computer and remove the wireless adapter and then boot up your computer, if it still does not boot up then the motherboard most likely been damaged.
I suggest you take it to a computer repair shop to assess the damage and give you a repair quote.
PC won't stay on, doesn't make it past the boot up menu
the fan on the CPU working? Try a different power supply the one you have might be faulty
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Tower Overheats and shuts off
The fan on your power supply is shot. Replace your power supply.
I HAVE ALREADY SEN T I DON'T KNOW HOW MANY E-MAILS TO THIS PROBLEM...IT SEEMS THAT NO ONE KNOWS WHAT IS GOING ON. I HAVE A SIMPLE PROBLEM THAT ANYONE WITH EXPERTISE AS YOU PEOPLE SHOULD, SHOULD BE ABLE...
Improve the Fixya.com experience for everyone by voting!
It happens periodically that our computer acts weird, won' print, won't properly load a driver, shuts down, restarts, or hibernates when we really don't want it to. I'm going to pass on to you a FREE and hard to believe program from Microsoft! I have no idea why this little program hasn't been advertised but then I don't own their stock.
Just click on the following link and your problem should be solved: Download Microsoft's Fixit
Be a hero and fix your friends' computers; just don't tell them how you did it! That will be our little secret.
All the best,
Ben
After shutting down my HP LAPTOP, it won't restart. If you push the "on" button, there's no response. I noticed that about 3 days before this happened, the system cannot...
- try to remove the battery of the laptop and unplug the power cord
- hold the power button for 20 seconds to drain the remaining power
- turn on the system
Screen frozen, can't turn off
Hold the power button down on the actual tower of your computer. After about 10-15 seconds the computer will turn off and you can restart it. If that fails, as a last resort pull the power cable out of the tower. It isn't as damaging to the computer as most people think but should only be used if the computer won't turn off any other way.
2answers
WINDOW XP WOM'T SHUT DOWN
Hold the power button in for a few seconds it will shut down. Then unplug system and push the power button down with it unplugged then replug it in and power up again. Then do a proper shut down again to see if the problem fixed. I hope this assisted you. John
2helpful
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Not finding what you are looking for?
    Steve Sweetleaf
    Steve Sweetleaf
    Grand Canyon Tech
    Grand Canyon Tech
