my channel auto-scan won't add any channels aside from ch 2 and AUX. i don't have the remote anymore and i am unable to add channels to the memory w/o this. please help.
You can't post conmments that contain an email address.
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
However, I do have a suggestion. You can hook up a vcr to your tv, then put the tv on channel 3 or 4 (whichever the vcr is set for) and change the channels through your vcr. You have to have the cable go first to your vcr and then out to the tv.
I would suggest that you disconnect the VCR from any signal source. UNPLUG the VCR from the power source [a/c] for at least one hour, more if possible. Before you are ready to plug the machine into a/c attach an antenna to the antenna INPUT, the VCR output goes to input of tv. [ DON'T attach cable box, or any such machine to the input of VCR.] Plug vcr into outlet and turn ON. Place TV-VCR switch on TV. [no remote control??] Change the channel MANUALLY, one channel at a time. If you see tv stations as you change the channel [KEEP changing until you have reached the " end of the line " of broadcast channels.] then you are good.Connecting the vcr to a cable box[ANY KIND!] you can only RECORD through the vcr what you watch on cable.
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
I HAVE A YEAR 2003 GE TV
MODEL 27GT630
THE MANUFAFACTURERE WAS THOMPSON LTD
I LOST MY SET UP MANUAL
I HAVE A CABLE
MY GUIDE PLUS REMOTE REFUSES TO WORK AS WHEN I PRESS A KEY THE LIGHT ON THE REMOTE DOES NOT GO ON
I HAVE BEEN USING A REGULAR GE REMOTE AND IT WORKED GREAT
SOME HOW WHEN I TURNED IT OFF YESTERDAY I AM UNABLE TO GET BACK THE TV STATIIONS
I HAVE BEEN FOLLOWING THE SET UP GUIDE ON THE TV
LOCATION CANADA
AREA CODE T9K 2G9
CABLE YES
VCR NO
WHEN I PUT ON THE AUTO CHANNEL SEARCH IT GOES THROUGH THE SETTINGS AND THEN SAYS "NO CHANNELS SELECTED"
IT IS A BEAUTIFUL TV AND I DONT WANT TO DITCH IT
HELP ME
You can watch the TV programs with the tuner of the unit. (Usually channel 3 or 4 of the TV is available for the RF converter setting.) Be sure to connect the unit to a TV using the RF cable. 1 Select channel 3 on your TV. 2 Press [VIDEO/TV] on the remote control. • If noise appears, change the RF output channel of the unit to CH 4 by pressing [VIDEO/TV] for 3 seconds. The RF output channel will alternate between CH3 and CH4
hey i sort of hav the same problem except, i cant access the "channel" with my sons game stuff on it
if i click menue then it just givs me "Picture" "Channel Set" "Language" "V-Chip Set-Up" "Captions" and if i click channel set i get "CH{TY}" "CH{CATV}" "CH{DTV/TV}" and v-chip asks me for an access code. and i got this tv from a friend and he lost the remote. i only hav an iO Digital Cable remote. help me plz
