Yamaha RXA1000 Receiver Logo
Posted on Jul 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After power outage, the units internal saftey switch has activated. How do i reset the reciever? It's a Yamaha RX A1000
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Jul 27, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2764899
Points
24828
If the protection circuitry has been activated 3 times consecutively you may have to contact Yamaha as it says in the Troubleshooting section of the manual.
http://usa.yamaha.com/products/audio-visual/aventage/rx-a1000_black__u/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Testimonial: "Thanks dunnbiker for your prompt reply greatly appreciated."
Yamaha RX-A1010 has a internal error message on screen
Need to take it in and have a tech reset the region. Somehow it got erased.
2helpful
Yamaha RX-V375 display internal error after power outage and everything works except radio tuning.
something wiped out the memory and the region code needs to be reset. I would suggest taking it into a shop that knows how to do this as I'm not sure that Yamaha wants the procedure sent out to the general public
Yamaha dsp a1000 won't power up
Your power suply is defective and needs repair.
Or the power amp is shorted will blow inside fuse power line
distribution.
21helpful
5answers
Yamaha RX V671 will not turn on anymore after a power outage
The protection mode has activated.
Reset the protection mode as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
How to connect bose 901 equalizer to yamaha rx-a1000
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input.
http://products.bose.com/pdf/customer_service/owners/og_901.pdf
Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
1helpful
Where can I buy a replacement selector switch for the Yamaha RX-750 Receiver?
Hi,,,
Try encompass parts on-line 1st If not there , try yamaha direct
Yamaha Parts Department at (714) 522-9011
PLease rate my help.
Thanks
2helpful
Yamaha rx-v563 just stoped working no power no displayed nothing have removed plug and tried other power points still nothing help
Check the internal fuse inside the unit. If it goes again, after replacement, get back in touch with us. If OK check the transformer and the power switch.
1helpful
120v plug in's on the back of my rx-v2400 will not send power to my mono block amps.
those are fused internally and made to power small items.the unswitched are constant power and the switched goes on and off with the power on the reciever.you have hooked it up to something that draws way to much power and more than likely blew the fuses.check the back by the sockets,they are rarely over 250 watts max.
4helpful
Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Reciever won't switch back on
you need to take it to the nearest yamaha service centre. Unit could have had a surge or blown a fuse.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
