As suggested by Kevin000 contact Sentry.
when this happens they ask your model number and give you a numeric emergency unlock key by phone.
As posted already by Kevin, contact is:
Sentry Safe
1-800-828-1438
www.sentrysafe.com
eventually give Kevin a Fixya if you sort it out.
Regards
I have this same safe.. It is fairly easy to pry underneath the black tab with a tool. You will most likely damage the safe so I would have to CAUTION you. THE other way would be to pry a small flat head screw driver in the lock itself with a hammer and the the lock should pop off. PLEASE IF THIS IS FOR MEDICAL REASON AND IT IS AN EMERGENCY YOU ARE GOING TO DAMAGE THE SAFE!
PLEASE post the model number the picture of the model is not the same as you safe.
Do you have to punch a key pad to unlock it or is is a key
HERE this will show you how
DID you have any luck
Please Leave a Rating for Kindofcheap
THEY ARE CLOSED FOR 2 DAYS it is a HOLIDAY IN THE USA
eventually give a Fixya Kindofcheap if you sort it out.
Regards
Trouble Shooting Tips in sentry safe;
Click on your locking mechanism below and we'll try to get you in.
hope this may help;
Can you please tell us the model number of your unit?
The quickest solution is to go to lock smith . the problem will be solved quickly. that way you will have the meds as soon as possible and the cost will be minimal.
You have to contact Sentry directly to get help on that.
Sentry Safe
1-800-828-1438
www.sentrysafe.com
try this ...
Just cracked my 1250 safe. If you've already got it open, take the
plastic cover off with a flat head screwdriver. You'll expose the
combination mechanism. Spin the combination wheel clockwise three
times, then turn it until the notch on the wheel closest to the door
meets with the latch. Write down the first number. Turn it counter
clockwise once around then do the same with the second wheel. Finally
turn the third wheel clockwise until the last notch matches up with the
others. Write down all three numbers and you have your combination.
Live in country no locksmith available on holiday weekend -- again husband gone (out of cell area -- opening dove season) need meds out of cheap ($150.00) fireproof sentry safe
Sorry - Model No. BD 21605
