Question about Dell Dimension 9200 PC Desktop
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
  • Dustin Kirkpatrick
    Dustin Kirkpatrick Jul 27, 2011
    How many beeps and how long? Think Morose Code. Is it like long-short-short?
    Novelist:
  • 129 Answers
Hiya:) This is from dell directly: Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. For example, beep code 1-3-1 consists of one beep, a burst of three beeps, and then one beep.This beep code tells you that the computer encountered a memory problem.
Reseating the memory modules (see Installing Memory) may fix the beep code errors in the following table. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
and here are the codes:
Code
Cause
1-3-1 through 2-4-4
Memory not being properly identified or used
4-3-1
Memory failure above address 0FFFFh
The following table lists beep codes for non memory related errors.
Code
Cause
1-1-2
Microprocessor register failure
1-1-3
NVRAM
1-1-4
ROM BIOS checksum failure
1-2-1
Programmable interval timer
1-2-2
DMA initialization failure
1-2-3
DMA page register read/write failure
3-1-1
Slave DMA register failure
3-1-2
Master DMA register failure
3-1-3
Master interrupt mask register failure
3-1-4
Slave interrupt mask register failure
3-2-2
Interrupt vector loading failure
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
NVRAM configuration
3-3-4
Video Memory Test failure
3-4-1
Screen initialization failure
3-4-2
Screen retrace failure
3-4-3
Search for video ROM failure
4-2-1
No time tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected interrupt in protected mode
4-3-3
Timer-chip counter 2 failure
4-3-4
Time-of-day clock stopped
4-4-1
Serial or parallel port test failure
4-4-4
Cache test failure
Posted on Jul 27, 2011
  • John Meijer Jul 27, 2011
    identify the problem and i will help you w/the next step if you need it:)
    New Friend:
  • 161 Answers
How many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
6ya staff
SOURCE:
Dell xps demension. When I turn on the power botton fan comes on at a really fast speed but nothing else comes on. Doesn't load anything??
A cool heatsink points to a CPU failure, as the CPU is not processing data. Replacing the CPU at first would eliminate this, however, the CPU is unlikely to fail first unless it had been severely overheated, more likely that the board has developed a fault.
If you are however getting no beeps on start up, this does look like the CPU is the culprit
Jan 18, 2011 | Dell XPS 200 PC Desktop
My Dell dimension 9200 doesn't start up anymore. It worked perfectly, went in stand by mode and I could not revive it anymore. When I start it, the fan works, the control lights flikker and go out again...
Hi it sounds like a RAM problem. i recommend you reseat the Memory sticks inside of the computer or you can follow this link directly from dell on how to isoltae the problem based on beep codes that you are getting.thanks
http://support.dell.com/support/edocs/systems/dim9200/en/SM_EN/adtshoot.htm#wp1054146
Jan 11, 2011 | Dell Dimension 9200 PC Desktop
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
No display on the Dell Dem 520
IT SOUNDS LIKE HARD-DRIVE FAILURE, TRY REINSTALLING THE OPERATING SYSTEM, BUT IF IT DOES NOTHING THEN REPLACE THE DRIVE
Jun 16, 2009 | Dell Dimension E520 PC Desktop
It "Chirps"
check to make sure all your bios settings are right if not you have a hardware conflict somewhere
Jul 21, 2008 | Dell Dimension 9200 PC Desktop
6 beeps at start up
Sounds like a processor or cpu failure.
Beep Codes
Please vote if you found this information useful.
Thank You
Apr 18, 2008 | Dell Dimension 4300 PC Desktop
Wont start
open the side casing of your cpu then try to switch-on, if you notice that the fan of your cpu rotates, the hdd led is lightng, the power-on led also lit then you heard a beep (one) sound there is no problem but your video card connection just loose
Jan 10, 2008 | Computers & Internet
Dell Dimension 9200 PC Desktop Logo
989 people viewed this question
Ekse
Clive
Clive
Alun Cox
