1994 Eagle Vision Logo
Posted on Aug 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RADIO PROBLEM I have a Sony Xplode head unit in my vision- cd player/tuner. You hear sound when the tuner is playing but when trying to play a cd, it reads the cd, tells you what song, how long is left,etc...but you cant hear anything. I was told that i would have to go thru chrysler to purchase a particular head unit because of the wiring in the 94. is this true or can i bypass this?
Anonymous
Level 3:
President:
  • Master 1,263 Answers
  • Posted on Aug 30, 2008
Anonymous
Master
Level 3:
President:
Answers
1263
Questions
Helped
683111
Points
4577
You should be able to get a factory connector for the unit that matches the stereo to the vehicle internal wiring. you will have to go to the dealer for this but you should not have to get a new head unit. please rate this solution....thanks
Ford escape no sound from cd player
no year told at all.matters huge. year 2001? to PRESENT.
2018 ford ended CD support.
all else works? FM /AM ,?
try 2 CD called CD-DA music disk. called brick store CDs"top labels"
many CD-r disk record-able do not play in cars.
many CD with Mp3 music do not play
the owner guide in the glove box does tells what the radio CD plays for the OEM radio sold day one. new.
watch out some Radio.or head end CD rigs can get 2 CDs jammed inside. (for sure slot CD type) kids do that most. failing to eject first the ram in a 2nd, causes huge damage.
Jump started a car, now radio turns on but no sound in speakers, any ideas?
jumping the car backwards has likely blown fuses or burnt out components of the system, you need the dealer on this.
Installed a Sony Xplode into a 99 Blazer and everything on the radio works but will not play through the speakers
The Bose system is complex - it has an amplifier separate from the Bose compatible radio. This amplifier takes low level audio signals from the radio, not full driver outputs from a replacement radio, and by trying to use the replacement radio you may have blown the amplifier. If that is the case, you may not be able to go back to the original radio.
The only option you may have with the replacement will be to find the Bose amplifier and bypass the connections to feed the replacement radio outputs directly to the speakers. This may not be as simple as it sounds, as distribution to the various speakers comes from the amplifier, not the radio, and the wiring from the amplifier to the radio may not have all the wires you need. Before going on, you had better get a wiring diagram for the Bose system (service manual or Alldatadiy.com).
Cant get sound when a cd is inserted
If you can only not hear sound when playing a cd then your cd player is probably not reading the disc or broken in some way. Buying a new head unit will solve the problem.
Hope I helped!!
8helpful
3answers
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
My 2003 Toyota Camry has an AM/FM radio with a tape player and a CD player. The radio and tape player work fine, but when I insert a CD in the player, it will not play 99% of the time. The CD activates...
Usually it is the drive unit for the CD. The linear tracking device that drives and guides the CD read laser is not tracking. Usually when this happens there is NO fixing it. You might just have to bite the bullet and get a new head unit.
CD player not working
Well, if you push the cd button and no cd player is installed, then you can try a salvage yard to find one and have an auto electric shop install it for you.
Otherwise, you can go to a place like Best Buy, and have them install a cd changer, like a Sony, for instance, that plays through a certain FM stereo frequency on your radio and they might be able to make it so that it powers up when you hit the cd button, although
many times they'll just have it power up on your ignition key being on, and you have to remember what frequency or preset on your radio to have to hear the cd-player play.
That's tech for you.
2004 freestar can't turn the radio up or down it
I would question your children " if you have any" if they have put anything in the cd slot, I work at a dealership and we find a lot of problems with the van radios are very nice children like to play and put small change into the cd slot, which shorts out the internal components of the radio, if you remove the radio, dash piece just pops off then 4 screws hold radio in, and shake it you should not hear anything rattling around in it.
Play my mp3 in 2006 Nissan Quest?
I was told the in dash radio unit will not play mp3's. as far as the dvd player, if you have the entertainment system i can't say. I do have two solutions for you.
1) the in dash cd player (mine is a 6 disc cd player) will not play mp3's at 128 bit compression, but for some reason or another I burnt an mp3 disc using the 256 bit compression, still smaller than the standard mp3 comparable cd quality, and unknowingly tried it in the cd player. The nissan quest played it. So it sounds as if the cd player is picky about how low quality of an mp3. 128 is a common reasonable quality. However, I was able to squeeze about 15 tracks on a 256 bit mp3 disc.
2) the in car dvd unit. If your unit is of the standard type, under the seat or mounted elswhere in the car, you could replace it. Dvd players sell for around $125.00+ and will play everything under the sun. reconnecting is not the biggest challenge neither.
& 3) You could purchase an additional hardwired device which allows you to plug in any audio device and play the sound through the Nissans sound system. The device into plugs directly into your wiring loom behind your factory radio. The best part is that the nissan system is already set up to receive this device. It will play through the sat1 or sat2 buttons. I searched and purchased the device online.
i had installed that before learning of the mp3 deal.
well good luck.
Sincerely, Flash
Top Eagle Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
john h
Are you an Eagle Expert? Answer questions, earn points and help others
