Hi The front cover on the camera (donut like shape that surrounds the lense, broke of as did the manual focus ring. Has anyone had this problem? Can they fix it? If I use super glue will the fumes damage the electronic circuits? ( as I was told by one store) Otherwise fixing it looks like it will mean getting a whole new lens. Martin
I had the exact same problem. The front ring fell off with the lens cap attached. Bummer!
I would not glue the two together. I fixed mine by removing the lens
body side, and screwing the front ring back on as it should be.
I noticed that there are tiny screws that are pointing forward, towards
the ring that had fallen off along with the lens cap. I carefully
removing the side cover of the lens body (about 5 screws), unsrewing
the (fake) hot-shoebracket, and the 2 screws underneath (where the lens
body where the camera mounts to a tripod), then CAREFULLY removing the
front end of the lens body assembly. There are ribbon cables attached
to it, so slide them out carefully. you will then see the offending
tiny screws either still in place, or rolling about in the piece. Match
the ring up to the front aligning the sensors, then screw the two
together. reassemble, and your back on track.
I would be willing post pictures of the procedure if someone needs to see how I managed.
I used Super Glue and my camer ia stil working. However you need to be very careful taht no glue gets onto the lens itself as it cannot come off and will give your pictures a blurred effect
super glue reacts to certain things especially body oils, so the fumes from the super glue can attach to oils on your lens especially a fingerprint which would be difficult to remove after that happens. acetone would work to remove but it would also strip the paint off plastic and could melt certain types of plastic. clear plastic could become cloudy. So stay away from super glue unless you have no alternative.
I would not glue the two together. I fixed mine by removing the lens body side, and screwing the front ring back on as it should be.
I noticed that there are tiny screws that are pointing forward, towards the ring that had fallen off along with the lens cap. I carefully removing the side cover of the lens body (about 5 screws), unsrewing the (fake) hot-shoebracket, and the 2 screws underneath (where the lens body where the camera mounts to a tripod), then CAREFULLY removing the front end of the lens body assembly. There are ribbon cables attached to it, so slide them out carefully. you will then see the offending tiny screws either still in place, or rolling about in the piece. Match the ring up to the front aligning the sensors, then screw the two together. reassemble, and your back on track.
I would love to see those pictures...I can't see those screws to retighten the focus ring
