Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
SOURCE: Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
SOURCE: 5 digit Remote Code for Centrex TV
You should only need a 4 digit code. Try 0056 for a Centrex TV.
Cheers
SOURCE: need codes for remote
have you tried these codes
http://www.hifi-remote.com/manuals/manual.shtml?URC-3605-codes
SOURCE: Infrared Remote codes
try to go threw all codes when you turn on and off the tv after each code and try to change channel after each code then the one that changes the code is the correct code!!! this might help.
SOURCE: Remote Codes for Motorola Cable Box DCT700/US
I have run into this problem with my Sharp Aquos as well. This is not necessarily a code problem but an interference problem.
If you take your hand or a thick book and sort of make a hood over the
area of the sensor on the cable box and place the remote right up close
to the sensor this will help let you know if the remote and the box are working
with the code. Also might try turning off the TV or unplug the TV to
test and make sure the remote will turn on the box.
Next thing after you determine this is how to block the interference
and be able to use your remote. What we did is placed the Wii on top of the box over the area of the sensor and this seems to have done pretty good.
Good Luck ....
1265, 0178, 0442, 0700, 0829,
0856, 1178, 1325, 1423, 1758,
1993
OK.
