SOURCE: pin code blocked
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1)
If you still have your packet that your Sim Card came in, you should
find your PUK number in there, if you don't have the packet, please
read bellow.
2) You must get a phone that is on the same network
as your phone and call the networks Customer Care and ask them for your
PUK number, they will ask you for your phone number, then they will
tell you your PUK number. Once you have done this, you will be able to
reset your Pin number so you will be able to go into your phone again.
Please also remember to give this solution a FixYa! rating if it helps you.
Kind regards
Dustin Ellse
SOURCE: I've tired to set the PIN code for my Nokia 6085 phone but I cannot.
HOLD ON!
You may enter wrong PIN three (3) times only. After that your PIN will be blocked!
To unblock, you need PUK. You can only enter wrong PUK ten (10) times. (This is as documented)
After entering correct PUK, you will be asked for NEW PIN.
So, when it says "PIN blocked. Enter PUK code", you must enter the PUK.
If you correctly enter the PUK, it will asked for new PIN, by asking "Enter new PIN code:". Enter anything you want as your PIN. You will be asked to enter it twice (two times).
From what I read from your post, you have done correctly, but you don't want to enter new PIN. There is no way SIM card/phone will use old PIN. The device doesn't know your PIN. So, you have to enter new PIN.
SOURCE: enter PUK code, asked for new PIN code, but then get "code error"
The card is totally blocked because you have been trying PUK codes before you got the code. !
Solution : Replace the card
Best Regards
SOURCE: nokia e71x pin code blocked , enter puk code
Service Provider will give the PUK Code....You can call them..
