Bunn VPR Coffee Maker Logo
Posted on Jul 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pot wont brew the water is heating up but it wont go past that point
Mike Cairns
Level 3:
  • Master 3,054 Answers
  • Posted on Oct 23, 2011
Mike Cairns
Master
Level 3:
Answers
3054
Questions
0
Helped
850350
Points
6358
I hope this helps.
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Thanks So Much, Mike
1helpful
Churchs bunn. Vps 04275-0013 started heating water till steam comes out fill hole. Causing water to drip everywhere....thinking a thermostate is not opening causing steam
Over Boiling or constant heating of tank water is an indication of a shorted thermostat (or out of calibration). Call your vendor for service. (especially if this equipment is on loan.)
*** the following is for information only. Repairs should be performed by a qualified Bunn Tech. ***
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
PS; There is a slight chance that your thermostat is set too high. There is a dial on the thermostat that can be turned counter clockwise to lower the temperature of the brewing water. Water should be about 190-205 F for coffee. Tea drinkers want 210 F which is too close to boiling point of water. If your in the mountains (+2000 feet) then the boiling temp will lower. Was it possible the brewer came from a low (sea level) location and moved to higher altitude? Then the setting is off and must be set lower (a fine adjustment). But note that if your on the top of a high mountain (like Haleakala, Hawaii) then it has to be set a lot lower and you will only get luke warm brews at 9,000 feet!. Adjust the knob clockwise to get it to boil. Then back it off counter-clockwise a bit till it stops boiling. Make another brew to check if the reheat comes to a boil but stops after a minute or so. It should not boil on longer than 2-3 mins. Back it off a bit more if it does. Brew again to check. If none of this works then you will need to replace the thermostat. If your at a really HIGH altitude location, then you will need a specially adapted high altitude brewer. Call your coffee vendor for advice.
I just bought the Bunn VLPF series, double burner. My other Bunn coffee pot had the option of make a half pot of coffee but this one does not Is there a tip to follow for half a pot?
Sorry this brewer is usually set up for a full pot brew. I have reset this for a small (but not half) pot brew as the customer wanted to use a metal carafe (with their own logo). I also tried once to get it to half pot brew but it can get tricky if you actually brew twice to get a full pot (in the same pot).
* there is a siphon action that starts once the boiler tank gets filled to a certain point. From that point it will continue to flow until the boiler is emptied to the level that stops the siphon action and leaves enough water in boiler to reheat for the next brew. Achieving the siphon point may be a larger volume of water for 1/2 a pot but may work for 3/4ths a pot. The 1/2 way mark may be affected by the brewers "level" while placed on a table or sagging in the middle of a weak table.
* Usually if you want a smaller brew then go with a smaller brewer. Though there is a hot water tap that will give you 2-4 cups of hot water (it gets tepid after that) which you can use for the "Mug" style brew. But it does get messy.ukeboy57
* Final, If you don't mind a little more than 1/2 pot brews then ask your vendor to adjust the machine for you. Though a reminder NOT the double brew in the same pot as it will overflow.
Aloha, ukeboy57
Hello. Bunn coffeemaker VPR Series. When water is poured in coffee starts to make. Carafe gets about 1/3 full and then just drips through filter for about 5 minutes. Never makes full pot.
VPS/VPR are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* Final; If your unplugging when not in use. Then follow the Pre-heat instructions mentioned above prior to plugging the brewer back in. If the tank has been emptied at night or dried up after an idle week. Then there is a chance you may over heat and blow the thermal fuse. Or at best have a half pot short brew as the water dried up.
* Note leaving the brewer plugged in without brewing daily is not a good idea. The water evaporates and eventually drys out the pot. Takes about 1-2 weeks but it does blow the fuse(s) and the unit will need service.
Aloha, ukeboy57
Have a bunn vps series pour over that won't brew
VPS are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on. Brewer will pre-heat the water (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* You can test the VPR by following the Pre-fill instructions I've listed earlier. If the brewer heats up and does not continuously boil (shorted condition) then try a brew. If it works then your okay. Otherwise the unit will need service for a blown high limit or bad heater element.
* Call your coffee vendor anyway. Many coffee vendors will service your brewer of even replace it as long as you buy coffee from them. Ask around.
Aloha, ukeboy57
My bun coffee maker model vps will not heat the water. I did notice bubbling noise the last couple of months, any thoughts?
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (CWTF's have a toggle switch behind the machine). Brewer will pre-heat the water (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* FYI Coffee grounds are usually in pre-messured packets for office use. A simple guide is one tablespoon per cup. (level or heaping spoon is up to you)
* Since your brewer was bubbling at one point. I'm guessing it had water in the pre-heater at one time. But if it's not in use and left plugged in all that time then the water has probably boiled off. Hopefully someone unplugged the brewer prior to the unit blowing the thermal fuse.
Aloha, ukeboy57
Water overfill
The A10 has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
PS. Check your using the correct size decanter for this brewer. If it's a 10 cup brewer then make sure all the decanters in the office is also 10 cup. Pouring a 12 cup pot into brewer will have 12 cups of coffee come out (over flowing the 10 cup pot.) Note that not all decanters are made the same size. Other brands may be different. Test by filling a pot with water (from faucet) then pouring directly into pot in question. It should match and not under fill nor over fill.
No hot water
You should call your vendor for service.
*** The following is for information only. Equipment should be serviced by a qualified tech. ***
Aloha, ukeboy57
Cant start the coffee
VPS/VPR (VP17-3 are the same except it has 3 lower warmers) are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
Aloha, ukeboy57
BUNN VPR NO HEATED WATER
You should call your vendor for service. Especially if it's on loan from them.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater powers up. Brewer will pre-heat the water (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* check bunn.com for free download of VPR manual
Aloha, ukeboy57
1helpful
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
