Televison & Video Logo
Posted on Jul 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi Ian unable to switch on my samsung smart tv purchased less than 2 weeks ago, only hear a clicking noise like when you first switch on with remote. Any ideas ?
dick davis
Level 3:
  • Samsung Master 610 Answers
  • Posted on Jul 26, 2011
dick davis
Samsung Master
Level 3:
Answers
610
Questions
5
Helped
222255
Points
1808
You should call 1-800-samsung and they will tell you what to do or who to call to get it repaired under samsungs' warranty. It sounds like the power supply board is defective.
Samsung hg40ee470sk secret menu?
Samsung Smart TV hidden secret menu allows you to do a factory reset and also connect some Bluetooth devices which you were unable to do before. Be careful while fiddling with these options as I cannot take any guarantee if you spoil the TV settings. The Samsung Smart TV I used in the video is Samsung F4500. The secret menu will not open with a smart remote. You may buy or borrow the original normal rectangular Samsung remote to access the secret menu but I am not so sure that will work.
Here are all methods to access the secret menu of different Samsung smart TV:
Method 1
Put the TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV on standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Method 7 for Smart TV RU7100, NU7090 Series 7 (suggested by viewer Caleb Harch)
Samsung Smart TV model UA32J5500AW unresponsive to remote regardless of distance.
1) Make sure nothing is covering the infared receiver spot on the TV. Might be something that simple.
2) Try a "universal" remote -- under $10 many places.
3) If you haven't done this already, unplug TV for a minute or two and when you plug it back in, may reset.
4) Contact manufacturer via their web site for help.
Unable to turn my smart tv on manually or with remote.
Lots newer sets have hidden menus and resets. Contact Vizio for reset on the set.
How do I fix the remotes to change samsung tv volume?
Just for the hell of it, change the batteries in one of the remotes and see if it works.
1helpful
Toshiba codes
Hi Ian,
The number or code that corresponds with your tv remote is "0".
Kindly click the link below to help you configure the remote control on talktalk.
Hope this one helps you.
Can use my TalkTalk TV remote control with my TV TalkTalk Help
3helpful
I have a Samsung sound bar Model HW-D450 which I purchased last week along with a Smart TV and Blu Ray DVD player. I think the thing is possessed. It is not compatible with the TV remote or the Comcast...
There is usually and option in the tvs audio menu to enable only an external speaker output. On the remote for the soundbar, at the very bottom-- there are buttons to fine tune the audio-video syncing
The screen is not sharp and dark, the HD is not like it was 2 yrs
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9600224C you can find it here; http://www.discount-merchant.com/SearchResults.asp?Search=BP9600224C?Click=48173 .Have a bless one!
5helpful
3answers
Tv makes clicking noise but won't turn on
it is a power supply issue. options 1- replace the power supply
2- this unit has an issue with 4 capsitors on the power supply which sit side by side and are about 10 volt each replace them with standard 16v caps.
1helpful
The tv will not turn on.
hi right now samsung is the best tv maker out right these problem dont happen with samsung what would be good to do is call them and let them know your problem cause you have a year protection on it thats if it less than a year
3answers
TV PROBLEM
No sir its not just an adjust ment or "twiddling" It sounds like its one of the same as your girlfriends set except a differant part such as a capacitor in the vertical curcuit, Output IC or even a defective resistor?? Good Luck
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
