My machine seams to go slow with a light load 500mb h/duty
  • Washing Mach... Master
  • 1,360 Answers
500mb from memory was a Hoover top loader ??? It could be just the belt slipping underneath, but also have a look inside the drain pump hoses for blockages. These were notorious for blocking with coins and other foreign objects. . If the machine couldnt pump out properly, when it went onto spin, it would only go very slow as the machine wasnt able to build up any speed with a full load of clothes and water.
Posted on Jul 26, 2011
6ya staff
SOURCE:
Does the top loader heavy duty machine have a filter and does it need to be cleaned regularly. If so, where is it located?
No filter to be cleaned in the machine. There are however small wire mesh filters in the screw on connectors that connects the water hoses to the machine at either the tap side or where it are connected to the machine inlets. Unscrew the hoses from the tap and machine inlets and check both hose ends if the wire filters are not to clog up over time resulting in slow water filling of the machine. Remove carefully and clean with a nylon brush. Replace again.
Aug 01, 2014 | Speed Queen 3.3 Cu.Ft. Heavy Duty Top Load...
Bosch front load washer...WFMC3200UC...6+ years old...light to medium duty...no problems UNTIL we now have an apparent slow leak into the drum when the washer is completely "at rest". I assume...
I would take the water pump ad trip it to clear the rotating shaft of possible cotton threds or other debris stuck in-between the rubber water seals as this can cause a slow dripping of the water as it creeps between the still shaft of the water pump eric
Dec 26, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
Down loaded new nortonantivirus from tiscali seams to be slowing down lap top any sugestions
Unfortunately many antiviruses tend to slow down things: they have to check each file on execution.
Check that your antivirus isn't scanning your whole system just now. Many antiviruses will do that upon first installation, to be sure they're running on a clean system. If that's the case, wait for it to complete.
If this happens often, there's a "speed" setting - fast scan will make the computer slow, but slow scan or "idle scan" will load the system much less. Try those.
Otherwise, maybe another antivirus might work better. I've always found ESET's NOD32 very light-treading even on not-exactly-bleeding-edge computers. Another one is AVG, of which there's even a Personal Free edition.
Nov 07, 2009 | Symantec Norton AntiVirus 2002 8.0 for PC
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a brother LS2125i it is easy to use, and I am a complete novice- but when I try to sew heavy denim- Like over the thickest part of the hem it makes a very load click nose- and becomes stuck--- is...
It may be the machine, although most machines would have trouble going over the seam. First, use a Denim needle, 90 or 100 and place a "shim" also called a "jean a majig" to keep the presser foot level. If the foot is shifted, the machine will not sew over the bulk. The machine is not real heavy duty, may have problems , anyway.
May 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
