SOURCE: breaker on the end of
I have had a few troublesome units over the year that did as you describe due to 'dew' overnight collecting around the tub and the increased moiture sent the motor of the circ pump "over the edge" iinto a grounded state. A leaking pump seal was adding to the problem. Once the seal leak along with the dew got high enough the GFI would sense the grounded condition and trip. Fixing the pump seal and drying/cleaning the motor fixed the problem every time. If you find any other leak sources around the pump you will need to fix them as well.
SOURCE: Dream Maker spa GFCI plug was all corroded. I cut
Did you make sure you observed the correct polaity on the cord? The white wire should go to the silver screw on the cord cap. The black wire should go to the gold terminal (brass) and the Green wire should go to the Green screw. If the plug was corroded, is it possible that the GFCI is also corroded? They aren't that expensive and you could replace the GFCI yourself if you're sure you can locate the circuit breaker and turn it off.
SOURCE: gcfi tripping
sounds as though you have a pump seal leak and water is seeping into the windings of the motor
