After cooking a meal the oven bake won't work, Broil works. When you turn on to bake the pre heat comes on, several clicks, lock flashes every so often, but doesn't heat up and fan does not come ob. Replaced control panel 6 months ago. Just tried to use self clean and the bake element heats up.
[email protected]
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
