Hi there
With most ( E ) errors A)E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste ink counter reset) and follow the described below procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) 4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks 0 time Green Power off
1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off) then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter the "service mode" Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release it. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Halo Barbara, Did you mean Pixma MP140/160/150/170/180?. I never hear Canon pixma MP10. Well,it doesn't matter. Did you refill your cartridge?. Error code E6 indicates that ink level is not detected properly by the printer. It usually occurs in refilled cartridge. To fix this problem you need to deactivate ink level detection function by performing following procedure: For MP150/160/170/180: Press START button (Black or Colour) For MP140: Hold down STOP/RESET button for about 9 seconds
Please rate me as Fixya if this solution useful for you. Thanks
following error codes i found E2-2 No paper (ASF) E3-3 Paper jam E4 No ink E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly E8 Waste ink absorber full, or platen waste ink absorber full
