Jenn-Air Electric Double Oven Logo
Posted on Jul 25, 2011
Jenn-air oven error code 4d22 - Jenn-Air Electric Double Oven
Elizabeth Greene
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Oct 15, 2014
Elizabeth Greene
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
6889
Points
18
Hi. Erorr 4d22 indicates that the control board isn't seeing the fan speed signal from the fan on that oven. It's the lower oven, right?
Check the connection to the Fan and Control board, and if that's not it replace the fan.
HTH.
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Dec 04, 2007
SOURCE: F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Anonymous
  • 146 Answers
  • Posted on Jan 07, 2008
SOURCE: Jenn Air W131 F1 error code
This means that the Power to element relay energized during time of day display. You have a problem with the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
Anonymous
  • 1314 Answers
  • Posted on Feb 19, 2008
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
Anonymous
  • Posted on Dec 30, 2008
SOURCE: The upper oven has faulty code 4d22 every time i try to clean
I just tried the suggestion to cut the power to the oven from the box for 1 minutes, and it worked! I feel like I just earned a day's pay!
Anonymous
  • 6784 Answers
  • Posted on Jul 27, 2009
SOURCE: Jenn air oven problem
HI. this is a Communication error between boards. Check the wiring harness that links the Power relay board to the Main board. if the harness is fouled on any way, replace it asap. if the harness is in good condition, replace the power relay board.
Jenn-Air model WW27430P. After heating to set temperature and baking for 8 to 10 minutes, why does it shut off?
It's faulty and in some sort of self protect mode. You need a service call or you can try some of the fixes here.
FIXED - WW2780 Jenn-air oven keeps shutting off ...
www.applianceblog.com > mainforums > threads > ww...
Feb 15, 2012 - Hi.... I have a Jenn-air oven model WW2780 that keeps shutting off after being turned on, almost always during the preheat. From what I have ... Missing: WW27430P ā€Ž' Must include: WW27430P
Jenn Air Range Stove Oven - Oven Won't Turn Off - Repair ...
www.repairclinic.com > RepairHelp > Jenn-Air-Oven-...
Here are the most common reasons your Jenn Air oven won't turn off - and the ... Enter model number to search for the required part specific to your product.
HOW-TO: Jenn-Air Oven WW27430P Door won't close
www.appliancepartspros.com > repair-help > ww27430...
Door won't close is the most common symptom for Jenn-Air WW27430P. ... I have a Jennair jjw9630cas double wall oven, and after a few years I noticed that the light would not go out, first in the bottom ... Door pulls shut and li8ght stays off.
HOW-TO: Jenn-Air Oven WW27430P Won't start or doesn't start
How to Replace Oven Temperature Sensor Kit for Jenn-Air WW27430P Won't start # ... Jenn Air stove JDS9860CDB00 error code 1d11 oven not shutting off. ... Very easy on this and other models with this sensor-- just two screws holding it in ... Rating: 5 Ā· ā€Ž123 reviews
Nov 17, 2020 • Ovens
tip
Jenn-Air Oven 4D22 Fan Error
I was troubleshooting one of these error codes on a Jenn-Air oven and followed all the repair recommendations. Most service techs recommend replacing the fan, speed sensor and making sure everything is clean. I did all this and it made no difference. After a bit more troubleshooting I found the temperature sensor to be bad. I replaced the temperature sensor and the fan fault code disappeared and the oven worked normally.
on Dec 09, 2016 • Jenn-Air Ovens
What does the FR error code mean on a jenn-air model W30400P wall oven during the self cleaning cycle?
FR Second oven error sensed
The unit never detected a sufficient rise in temperature in the second oven.
Error code -fc- beeping will not stop?
From JENN AIR FAULT CODES...
FC - Communication error between boards - Wiring harness or power relay board (PRB)
Hope helps.
3helpful
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
I have double oven my lower oven is not working appears a code in the screen that is not allowing to work the lower oven i restart unit in the code disappears but letter around cameback the code to the...
The exact same thing just happened with my lower oven and the code 4d22 appears in the upper right part of the display panel by the the timer. There is no explanation for the code in the instruction manual. Hope someone can help us with this. Upper oven works fine.
1helpful
2answers
Lower oven
hi
shut off power to the unit, let it sit for a while then turn the power back on. test the oven again, if the code comes back call 1-800-Jenn-Air and ask them what the code means.
JJW9830DDS
THE SOLUTION WAS TO CALL FOR SERVICE. IF YOU CONTINUE TO USE THE UPPER OVEN , THEN THERE IS A POSSIBILTY IT CAN CAUSE A FIRE IF THE BLOWER IS NOT WORKING. THE COST OF THE REPAIR FOR REPLACING THE BLOWER WAS ABOUT $390.00. THEY NEED TO REMOVE THE OVEN FROM THE WALL CAVITY TO PERFORM THE REPAIR.
1helpful
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
