Got a craftsman convertible 32cc gas trimmer/edger that i got new replacement fuel lines for, but am not sure where what line goes where. i need a diagram from the gas tank to carb.
Hi davemac918...
I used a long pair of tweesers to grab the filter, but you can also grab it with a piece of wire with a hook bent on the end of it large enough to fit the tubing the filter is inserted into.
Hook the filter tubing, and pull the filter to the top of the tank and manuver it out of the tank.
Please take time to rate me
This problem seems to be the biggest and most popular one by far in these forums and has been answered several times. Try and post your problem using the search feature on this site. Don't use too many words. Craftsman Weedeater Fuel Lines should be sufficient. If you can't get it, then post back here again please.
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Look carefully at the 2 nipples on the carb. You can tell one is slightly larger than the other. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. completing the purge circuit. This info pertains to the Craftsman 32cc with Zama carb and may work on the 25cc model as well.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
