SOURCE: KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
SOURCE: microwave over the stove
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
It may also be a problem with a door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Microwave Shuts off...
It sounds like you may have a loose fuse holder or an intermittent part such as one of the thermostats, such as the one mounted on the magnetron.
One thing to try is to cook on the lowest power setting or defrost to see if it runs longer or fails more quickly.
If you or someone you know
disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
SOURCE: Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
SOURCE: Microwave doesn't work after house fuse blew
Check the fuse inside the microwave. Unplug the power, remove the case screws on the back of the main case and slide the case toward the back. Remove the outer case and look for a fuse that looks simular to an old automotive fuse, usually near or just above the control panel. Check the fuse to see if it is good, if not replace with the same and reassemble reversing method used to access the fuse. Note: automotive fuses will not work. A replacement will be available at The Shack or a local appliance parts store.
Testimonial: "Thanks very much Woodmanns77 - It cost me $2 for the fuse (actually a pack of 5!) and I did it in 5 minutes - you've probably saved me $80 or so. Geo"
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
Make sure the !!!!capacitor is
discharged!!!!! before attempting any sort of repair.
Check
the door interlock switches first then the high voltage diode with
either an AVO model 8 on high resistance range for short circuit, the
capacitor can fail and go short circuit, the feed fuse on the primary
of the high voltage transformer and then finally, the magnetron is
best checked by substitution.
Hope that helps
