SOURCE: craftsman compressor will not come up to pressure
Don"t worry, even the best techs overlook a thing or two during repairs. Lets go over some basics to determine where fault is located. You will need to do some simple tests. If there are leaks the compressor may not reach set pressure. I use soapy water on all connections and on the head/headvalve while compressor is running. Make repairs as necessary. If still low pressure, while compressor is running and has reached max obtainable pressure (still low 70 - 80 lbs), carefully place finger over intake port hole (remove filter). If the compressor is pumping normally but leaking there will be ample suction at intake and cause the compressor to speed-up when intake is obstructed with finger. If you feel plenty of suction and no visible (soapy water) leaks, then the problem is probably the cylinder /ring is not correctly seating and air is leaking past cylinder. Make sure that the cylinder /piston ring is properly alighed and that the lip on the vinyl ring is up toward the head. If you do not feel suction but rather air seeming blowing out of the intake, then the problem is the headvalve plate/reed valves are leaking. The reeds must seal perfectly on their seats and not bent or have obstruction. Replace as necessary. Only one other thing to check and that is the intank check valve. Easy to check. Run compressor till you have about 70 lbs in the tank then unplug compressor. Carefully loosen the inlet hose at checkvalve and listen for air leaking out of tank. If leaking replace checkvalve. Use caution when removing head to try and save the gaskets. Good luck on your repair and email if you have other question.
SOURCE: Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
SOURCE: air compressor will not switch on
Make sure that your outlet has power to it. With the compressor unplugged, open the cap on the pressure switch. Work the on/off switch and see if the contacts are engaging/disengaging. If they are carbonized, you can clean them with a fine sandpaper or emery board. Look for loose wiring and tighten all wiring connections.
Regards, --W/D--
SOURCE: My craftsman air compressor model 919 16737 1.1 hp
Probably the check valve has failed. It apparently is where the pipe goes into the tank from the compressor.
