Unfortunately if the scanner is unlocked and you have reinstalled the software with no luck, then the scanner is defective.
If your scanner is still under warranty you can get a free repair or replacement form Canon...your best bet would be to contact them via one of the methods listed here:
http://usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
The LIDE scanners are nice, I understand your frustration.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
I had this problem with my Canon LiDE 210 which gets its power only through the USB port cable ( no separate power connection). I just plugged the scanner into a different USB jacks on my computer until I found one that provided adequate current to power the scanner motor and circuitry, then that "switch lock" error message stopped appearing. Most computers are made with different USB ports able to provide different amounts to power to peripherals, so check your computer manual to see which USB jack can provide the most current.
Thank you, thank you, thank you!! @peter_thompson211 -- You saved me a LOT of hair-tearing. I was about to toss the thing out the window!
Thank you so much Peter. I was really desperate and now the blood thing works agains !
my printers shows an error message....angd the sound once the cable is plugged and start scanning,,,,,cannot pushed through....what is happening to my scanner?
This problem can occur when there is not sufficient power from the USB port. I once had this problem when I connected the scanner to the USB port on a hard drive that was not itself plugged in. When I connected the power to the drive the problem went away.
It is also sometimes a problem with a specific USB port that is providing low power. Simply by swapping to another port you can sometimes solve this problem.
thanks. I was hoping for a better solution but i guess its just not gonna get fixed.
Peter Thompson's solution is the one that works. The "oh it's broken" solution sounds like something a customer service rep who has no clue would say.
Where is the lock switch?
Peter Thomson solved my problem in 17 seconds.
pls sir lamp lock
