LG WD-1080FD Front Load Washer Logo
Posted on Aug 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost manual and malfunction
Hi. Just wondered can u help me. My washing machine 12mths old. It is not spinning properly and error message I think 0 and back to front 3. Lost manual and cant decipher code. water still in machine. purchased Harvey Norman. Do you know what the error message is and how do I go about getting a replacement manual! thanks The model is LG WD-1049C
  • raycindy Sep 13, 2008
    Thanks for your help!! It was a blocked hose. $14 worth of coin!!!!
Anonymous
Level 3:
  • Master 706 Answers
  • Posted on Aug 31, 2008
Anonymous
Master
Level 3:
Answers
706
Questions
0
Helped
313264
Points
1939
  • Anonymous Sep 13, 2008
    Glad you were able to get it resolved...
    Enjoy !
1helpful
My Midea front loader won't spin. HELP!
There are a few potential causes for your Midea front loader washing machine not spinning. Some possible reasons include:
  • Overloading: If the machine is overfilled with clothes, it may not be able to spin properly. Try removing some of the clothes and running the spin cycle again.
  • Belt problem: The belt that connects the motor to the drum may be loose or damaged, preventing the drum from spinning.
  • Drainage issue: If the machine is not draining properly, the spin cycle may not be able to begin. Check to make sure the drain hose is not clogged and that the pump is functioning properly.
  • Control Board problem: The control board is responsible for controlling the machine's functions. If it is malfunctioning, it may prevent the machine from spinning.
  • Lid switch: The lid switch is responsible for detecting if the lid is open or closed. If the lid switch is faulty, the machine may not spin.
It's best to check the owner's manual for troubleshooting steps specific to your washing machine, or contact the manufacturer for further assistance. If the problem persists, it is advisable to get it checked by a professional technician.
I have a LG 1445TD and i want to be able to set just a rinse and spin cycle to freshen up the load if ive forgotten to take the clothes out the day before like whats just happen without going through a...
(start rant) It still amazes me that new washing machines, other than those sold in the UK, seem not to have manuals placed inside the drum/tub! I think that purchasers should demand one from the vendor and threaten to go elsewhere if it doesn't supply the goods! (end rant)
Of course the manual could have been lost!
Methinks you could do with a manual- for now and later!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
2helpful
I have an LG WM2487h*ma model. It trys to spin during all cycles but turns a few times then stops, then trys again. Never gets to full spin capacity. Tried small load, and big load. Watched during a...
Hi!
I think there is nothing wrong with your washer. The UE error means Unballanced Error. This error comes up in two cases: 1. the load is distributed unevenly in the drum or 2. the machine is not properly set on an even surface (floor).
Of course, it could be a third case possible, but very unlikely, when the ballance sensor itself is malfunctioning and have to be replaced, or the spring and dampers are worn out and also have to be replaced.
Hope it helped!
Best regards
When i start program de keeps coming up
'de' on LG machines normally stands for Door Error - it thinks the door is not closed properly. This means that either the interlock requires adjustment, if that is physically possible on your machine, or the sensor is malfunctioning.
Whichever it is requires a service engineer, sorry ;-0(
Good luck,
John C
My washer seems not to spin properly during the rinse cycle and will not spin now i get what i assume is an error message ue when its time for the spin cycle to begin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
6helpful
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Bosch Excel 1200 wahsing machine, when trying to activate spin, it shows the normal 10 minutes, but then goes straight from 8 mins to 1 min and items arent properly spun
bosch exxel 1200 washng machine
has error message 04 and wont drain or spin
what does this mean?
can you help?
have lost instruction book
My Bosch washing machine not working properly
Does the tub turn at all when you start it?
Sam
Melbourne Domestic Appliances
Text 0424395512
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
