Lexmark X4650 InkJet Printer Logo
Posted on Jul 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello I have a Lexmark X4650 printer. I was printing earlier this morning and then suddenly, the printer stopped working and gave the error message that left cartridge is incorrect (I haven't touched the cartridges and there is ink left in both). I've taken the cartridges out and put them back in, I've cleaned off the copper looking connections, and I've turned the printer off and back on. Any suggestions? The printer is 1 1/2 yrs old and am wondering if it hasn't just "died".
  • Official Brand Answer 3,344 Answers
  • Posted on Aug 02, 2011
Fixya Pro
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
922899
Points
5508
Good job in re-seating the cartridges into the printer. Try to insert a different known working cartridge to determine if your other cartridge has gone bad.
Paper aligns but nothing will print on Lexmark x4650
Are you getting any error msgs when you try to print? It's possible that you have a communication problem. Make sure that your computer and printer is able to talk.
Since no details were provided, you can try to uninstall the Lexmark software and download an updated driver online at www.lexmark.com.
2helpful
Cartridge Error - see user manual
It seems that you have tried most of the troubleshooting steps to identify and fix the problem. But try to replace your black cartridge with a new genuine Lexmark cartridge to determine if it's a faulty cartridge issue.
You may also contact Lexmark Technical Support Center for additional assistance.
I have a lexmark X4650 and the quality of the printing suddenly went very poor. Smudged and not clear at all. The printer is not used heavily and I have tried alligning the cartridges and cleaning to no...
Try to check the ink levels and make sure it's good for printing. Otherwise, please replace them with new cartridges. You can try to re-seat the cartridges in the printer then try to print your document again to verify that the print quality has improved.
After scan, whatever save function is used the error message "printing application has stopped working" appears with the only option Close Application.
Try to re-install the Lexmark X4650 driver. Visit the Lexmark website at http://bit.ly/iofMNC. Select your operating system, download the driver and execute the file.
5helpful
Lexmark X4650 needs new ink cartridges but I've losst manual. How do I get in it please?
Welcome to FixYa!
1. Make sure the printer is on.
2. Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid.jas247_10.png
4. Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Thank you for using FixYa!
Keep me posted!
Jas247
I had my x4650 series printer connected wireless and it worked fine for about 2 weeks. All of the sudden it would not print anymore. I uninstalled it, and reinstalled with the driver disk and connecting to...
It seems that the driver and software has incompatibility issues with your computer's Windows version or Windows might have downloaded and installed an update that caused this problem. I suggest first to visit Lexmark x4650 support & downloads website to download and install appropriate drivers by selecting your windows version (XP, Vista or 7). Remember to uninstall existing software & driver first. If problem persists, contact your printer's manufacturer for assistance.
This is your printer manufacturer's contact details.
http://www1.lexmark.com/content/en_us/about_us/contact_us.shtml
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Lexmark x4650 cartridge problem
maybe your ink is empty. you need to change you cartridge
Today all of a sudden the printer won't print. I
Check to verify you are sending the print job to the correct place.
2answers
Won't Print x4650
Hi
Here are a few possibilities...
1. Try cleaning the contacts on the inkjet cartridge and where they make contact inside the printer. (use cotton wool and Alchol) if that does not work...
2. Pull out power cable from printer wait 1 MINUTE then insert cable and switch back on again. (some printers reset to factory settings)
3. Remove printer cable from computer... Uninstall Printer driver from computer... Switch off both printer and computer. Wait 1 minute... Reconnect cables and switch on printer and computer... Allow computer to find printer reinstall driver.
4. Try installing old cartridge to see if printer rejects that?
5. You may have a faulty inkjet cartridge (return it to store if so)
You may find more help here...
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
2helpful
2answers
Hardware installation
I did a web search and ended on a forum where everyone was complaining that they could not get drivers.
But one person (user name Arthur) said that the problem is solved by printing from a virtual machine that runs on top of Linux (for instance Virtual Box). Arthur claims that the printer worked through USB as well as WIFI. Sounds Neat.
You might try that solution.
Hope it helps.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
