LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
Posted on Jul 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an LG LFC25760ST that the door alarm continues to beep even after the door is closed. I do not have the fancy control panel with an on/off button, I only have a temperature control. Any help would be appreciated.
Anonymous
Level 2:
  • Expert 489 Answers
  • Posted on Jul 24, 2011
Anonymous
Expert
Level 2:
Answers
489
Questions
0
Helped
299377
Points
854
You have a bad door switch at the top hinge cover. More than likely, a wire has come loose. Can't tell which one since there are 2 of them. You will need to disconnect the wires and check with a ohm meter.
Good luck.
3answers
On my lg French door refrigerator it is beeping intermittently. The temperature led on the front changes by itself. It is cooling.
I had the same problem with my LG side by side fridge. After lots of hassles I found that one of the switches on the control panel had moisture in it. After changing the faulty switch all my problems were solved. No more beeping by it self and all the buttons work fine.
2answers
LG fridge LFC25760ST beeps and increases temperature intermittently when door is opened.
Why does it keep beeping even though the doors are closed?
  1. Check to see if the fridge and the freezer are overfilled Over-stuffing in the freezer or the fridge or both of these compartments will prevent the doors from closing properly and which can cause the fridge's to set off the beeping alarm.
  2. Check the fridge door seals: Broken or damaged door seals may stop the fridge from closing all the way. This can also happen if the seals are dirty. Wipe clean the door seals with a soft cloth and warm and use soapy water and close the fridge doors. If the door still appears ajar then you have to replace the door seals.It is also quite possible that the inbuilt door-alarm which sets off if the fridge door is ajar for more than a few minutes has gone bad . This would need to be looked at by a qualified repair person . Until, you can call a repair person transfer all the food items to another cool place.
  3. Check the fridge balance: To work correctly the fridge must be placed on a levelled surface. Even a slight tilt in the fridge structure can set off the beeping alarm. Check to see if the fridge is balanced evenly.
  4. Check to see if the fridge exterior is warmer than usual: Check if there is adequate distance between the fridge and walls to allow for proper ventilation. If you have already ensured this and the fridge exterior still appears warmer than usual, have an appliance engineer to take look at the problem. If the beeping continues, switch-off the fridge.
  5. Check the freezer: If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm to go off . If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
  6. Have a repair person check the circuit board: It is possible that there is an issue with the appliance's circuit board. If so it will most likely need replacement.
2answers
GE refrigerator constant irregular beeping
It looked like your model does NOT have an external ice/water control panel which has caused beeping problems on some models.
For your model I would try the following....
Door Alarm
The main cause of a beeping GE unit is an open refrigerator door. Some models are equipped with an internal door alarm, which trips when the door remains open for 3 minutes or longer.
One way to check this .... put your smartphone in the refrigerator on video mode and close the door. The light should go off with the door shut. If the video shows that the light stayed on when the door was closed ... then it reinforces that something is wrong with the switch/alarm. Repeat video for the freezer.
Door Seal
If beeping persists after the freezer or refrigerator door is closed, the door seals may be blocked or so dirty that the internal door alarm is tripped. The seals can be cleaned with a soft cloth and warm, soapy water. Also, an item inside the refrigerator may be preventing the door from fully closing.
Cooling System
Reactivating the refrigerator's cooling system includes a beeping noise. When the refrigerator is off, the "Off/Off" light appears on the door display. When the "Adjust Freezer" and "Energy Saver" buttons are held down for approximately 3 seconds at the same time the beep sounds and the "Off/Off" indicator disappears. Hold the "Ice Off" and "Freezer" buttons to activate the cooling system inside of the fresh food compartment. A beep signals the system is activated. The beeping should stop after the cooling system turns on. If it fails to stop, try unplugging the power cord to reset the connection.
Power
The GE's internal door alarm can get stuck. Try unplugging the refrigerator for about 10 seconds and then plug it back in. If the beeping continues, the internal door alarm might be broken or defective. Contact the manufacturer or a technician for further assistance. One way to check this .... put your smartphone in the refrigerator on video and close the door. The light should go off with the door shut. If the video shows that the light stayed on when the door was closed ... then it reinforces that something is wrong with the switch/alarm.
Good luck on your troubleshooting!
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
2answers
Whenever I open the door the beeper starts beeping and continues for 19 beeps regardless of whether I leave the door open or close it again. The beeps are at approx 1 second intervels
Whenever the fridge is open it gives 19 beeps actually.In your case even when it is closed it is giving 19 beeps.This is the problem with control board.The control receives the signal when closing the door and stops the sound.Check the wiring connection to and fro the control board to the door.Control board costs high.This is small problem you can just unplug the wiring connection to the door to the board instead of spending more.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
How do I remove the lights in the refrigerator section of my LG LFC25760ST? Why would the lights not go off, even with the door closed?
this is not really a solution, but good information. this past Just a class action suit was filed against LG for knowing about the light bulb problem and continuing to sell the fridge.
3helpful
2answers
LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
2answers
Beeping sound
ok the only other option the latch located in the fridge has a loose wire which need to repaired by a fridge tec but also if the fridge seems like its not getting cold the thermostack that make the fridge cold may be malfunction
any how it needs repair
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
