SOURCE: CALLER ID ONLY SHOWS "INCOMING CALL"
have the same problem with a Panasonic KX-TG9344T phone bought from USA used in india. is it a local generated problem?
SOURCE: panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Carl
SOURCE: nortel norstar m7310 phone caller id problems
did you change extension numbers? Or did your extension number move with you?
SOURCE: Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
SOURCE: caller Id on phone
If you have it on other Panasonic phones, it should be automatic if the phone is made to ring.
If you don't have it, you need to call your Panasonic dealer. It requires hardware and programming.
Carl
To add caller id card and do programming
