The f2 code means the their is a problem with the oven sensor
the sensor is a electronic thermostat if you know where to find in to check it unplug it and insert meter leads set to ohms setting, at room temp. the meter should show between 1060-1100 ohms (in the midsts of this heat wave it may be up to 1150 ohms) if the reading is higher or lower than that the sensor should be replaced
