Computers & Internet Logo
Posted on Jul 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My compq laptop won't start up. I only have it since last Christmax. I have tried turn laptop upside down and power off. But nothing worked so far. It just won't go through the start cycle.
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 214 Answers
  • Posted on Jul 24, 2011
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
214
Questions
Helped
63547
Points
450
Go to Compaq and get them to resolve the issue or replace the PC.
http://www.compaq.com/country/cpq_support.html
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
tip
Computer won’t turn on
Computer won't turn on
This is probably the no.1 problem faced by many of us. To understand this problem, you can compare it to our human body.
When we are sick, we often get a fever. It's the body mechanism to fight infection. In the same way, when the computer faces any problem, it usually won't turn on until you fix that.
There are hundreds of reasons why a PC won't boot up. The issues can range from power supply failure to virus infection. Normally, by following the steps given below, your computer should be able to start.
Solutions:
1. Check the power supply
  • If it's a laptop, a loss of power could result from a battery that has completely run out of charge. So, the first thing to do is to plug it in and leave it to charge for a few hours. If that doesn't work, it could mean the charger is faulty, so, if you can try a different charger. If the charger has a power indicator, check whether it lights up when you plug it in.
  • If your PC is a desktop computer and doesn't start, check that it's not the plug socket at fault by plugging it into a different socket. If that doesn't work, it could be that the power supply in your PC has failed.
2. Make sure the monitor or display is functional
If you can see that your PC has power, because the fans start-up or the power lights come on, but nothing else happens, there are a couple of possible faults.
  • If you have a desktop PC connected to an external monitor, it could be the display that's faulty. Check the power connection to the monitor and that it's properly connected to your PC. Try disconnecting it and reconnecting it. If that doesn't work, try connecting a different monitor, if possible. That way you'll be able to either determine it's the monitor's fault or rule it out.
  • If you have a laptop, or if you've ruled out the external display, it could be that your PC is in sleep mode and is having trouble waking. To check that, shut it down completely and restart from cold. To do that, hold down the power button for 5 seconds and then press it again to start your PC.
3. Eliminate external hardware
If none of the steps above work, the peripherals could be the culprit. This could either happen because of electrical issues or external hardware failures.
After doing this, try restarting the system again to see if it works or not. If it doesn't, move on the next final step.
4. Reinstall system
If none of the steps work, the last thing you would want to do is to reinstall your Windows. Because till this point, you can be sure that it's the software and not a hardware issue.
Since you can't turn your computer on, there's no way to get access to your file. However, there are methods to backup your files from the hard drive. A clean installation will help to reset everything back to normal, should your system is infected or corrupted.
on May 09, 2022 • Computers & Internet
My Toshiba laptop wont POST
Sounds to me like a fault on the Primary Circuit Board. to test if it's the motherboard, try unplugging the laptop, turning it upside down, removing the battery, taking the RAM out of the pc and starting the laptop without and RAM inside it. if you dont hear the motherboard beeping it's not a good sign :(
1helpful
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
2answers
I have an emachine m250 laptop and accidentally spilled tea on it. I instantly turned it upside down and cleaned it fast. I believe only a little got inside through the keyboard. I was able to save my...
you should let it dry for awhile. Sometimes you are okay after a liquid spill as long as you let it dry, but other times it can fry your motherboard. I killed one of mine that way too.
1helpful
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Toshiba Satellite laptop will not boot. Shows power from outlet and battery but no indicator light is present for the last two in the five light sequence.
Its an old trick that got my Dell laptop working
Unplug the laptop remove the battery press the power button,...nothing will happen, wait a few seconds put battery back in laptop plug it in hold upside down press power button until it boots
If that doesn't work it could be a bad/loose/dead bios battery What is the model of the laptop?
My hp compaq nc4400 does not detect its hdd
Hi
you could try this it sometimes work
turn off laptop and unplug power cord
find the panel underneath that holds the hard drive usually 2 screws
remove panel and remove the hard drive
If you are not sure how to remove the hard drive ( not difficult )
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01884372&printver=true
turn laptop up correct way and try to restart laptop
it wont start up because you have removed the hard drive
now switch off again
turn upside down again
replace the hard drive
replace the panel
turn up correct way
and try to restart the laptop again
if this dont work
now turn off and on again pressing the F8 tab a few times to see if it takes you into repair options
and try the back to last known good configurations
or try some of the other repair options
hope you get it sorted
many thanks
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
