Question about GE Profile WPRE6100G Top Load Washer
I have a GE washer, model #WBSE2090A0WW, that will not fill up with water very fast. It works fine once it does fill up. We've checked the hoses and screens to make sure they didn't have hard water build up, and the pressure is fine before we connect it to the machine.
    President:
  • 3,773 Answers
HI,
Then water mixer valve needs to replaced. That's the valve that the fill hoses attach to at the back of the washer.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Posted on Jul 24, 2011
  • 4,070 Answers
Disconnect the hoses from the water supply and look at the screen filter in the end of the hose. The cold water usually gets sediment and can clog the screen.
  • GE Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
6ya staff
SOURCE:
Cabrio washer won't fill normally but diagnostic shows valves are fine
when doing the diagnostic testing machine fill up almost full and stop display an ol mode
Apr 17, 2013 | Whirlpool WTW6400SW Cabrio Washer
Frigidaire gallery top load washer
After 13 appliance years, your washer is a candidate for replacement.
Aug 08, 2017 | Frigidaire CWS3600AS Top Load Washer
My machine start to fill with water and about half way full the water starts running out juswt as fast as it is going in
Check the drain and see if the drain valve or pump is open due to clogging of dirt. If so back flush the drain and reset the unit , drain pump.
Jun 11, 2012 | GE Clothes Washer Model Select Connector -...
Washer won't hold water, just drains to the floor.
Sounds like there's a hole or loose ejection water hose.
Move the washer so it will run and you can look in the back to see where the water is coming from....fix the leaky problem once you find it. Could be a bad hose clamp as well
Dec 12, 2017 | GE WBSR3140DW Top Load Washer
GE Top load Washer Model wwse5240g2ww fills with water and then does nothing else
This may require a technician visit, but you can check this:
Open front panel by using a putty knife to push in and release a clip at the seam where the front panel meets the washer's top. (usually about 2 inches in from each side.) Look at ( BUT DON'T TOUCH !!!!!) the motor. Just under the top plate on the motor is an electronic board which has an LED mounted on it. Anytime the washer is plugged in, the LED should be slowly flashing, about once a second. When the motor is running, it should flash twice as fast. If you get anything else, like four flashes, a pause, and four more flashes, call for service and let them know the flash code you are seeing.
Nov 18, 2011 | GE Washing Machines
GE washer model WBSE2090A0WW control assembly replacement
hi. I was also searching for the same part and got the same result; nooo, the unit is smaller and only has spots for two knobs not four.
have you looked at this site? https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=PARTSRESULTS&AppliancePart=Washers and Dryers_Miscellaneous .... if that link doesn't work try this and navigate thru it.
There is a guy who lives down the street from me who owns an electronics repair shop; I will be taking my control assembly to him. I'll let you know what he says. On my circuit board, there is a "brown" solder joint; all others are the normal silver color. Hopefully the guy can fix the component that hooks up to the solder connection (it's a relay).
I've been having trouble w my washer (same model as yours) for a couple months ~ I've troubleshooted everything!!!
Hopefully we don't have to end up buying new washers!! take care. (I'll let you know what my neighbor says, too ... thx)
Jan 02, 2010 | GE Washing Machines
GE washer model WBSE2090A0WW HELP
Sounds like your loosing your cycle timer which controls all the relays.I would try buying a used one just as a test.
Feb 21, 2009 | GE Washing Machines
GE Profile WPRE6100G Top Load Washer Logo
325 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
