Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
Posted on Jul 23, 2011
Dcp-j125 printer shows error message 50. paper jam. There are no paper seen as such from both back and front. Iv cleaned the printe rencoder slip. but no go. same error message:- init.50
  • FRAMELESS1
    FRAMELESS1 Feb 23, 2016
    Clear the paper jam. If the problem still continues after clearing the paper jam, try to clean the encoder strip behind the printer head
    (((( or some sensor problem. )))
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3222
Points
5
Unable to clearn 50 open the back cover remove jamed
5 Related Answers
Anonymous
  • Posted on Jun 28, 2011
SOURCE: Error: init unable 50
init unable 50 how to resolve this problem..?
Anonymous
  • 812 Answers
  • Posted on Jan 28, 2011
SOURCE: my mx 300 keeps saying
Hello thanks for using fixya
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon service provider.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Testimonial: "thank you"
Anonymous
  • Posted on Jan 07, 2011
SOURCE: Init unable 50 appears on
clean unable 46
Anonymous
  • Posted on Aug 17, 2009
SOURCE: not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Anonymous
  • Posted on Jul 17, 2011
SOURCE: DCP j125 Inkjet printer stopped printing showing
well, cut the small piece of black tape (or you can use black permanent marker) and then cover the sensor of the cartridge, once the device will ask you to reinstall the cartridge and new system will detect as a new cartridge
2answers
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured.
You need to pres Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press the Up Arrow and numbers will change and press OK after the one you want to select. The number sequence is the following. 8-0 2-8-6-4 4-4-6-0 7-7 9-9
1helpful
Unable to init 50
paper jam or some sensor error, try to clean the sensor located at under the pump.
62helpful
4answers
21helpful
3answers
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
8helpful
2answers
Error 50 brother dcp 130 d
on my DCP 130C display appear an errore message "imp. stamp 50". This is an error message in italian language that indicate impossible to print, error 50.
Please, have you some suggestion to resolve this problem?
Thansk in advance
3helpful
Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Norman Weimar
Norman Weimar
k24674
