If you do not have communication by the printer when connected by USB cable to the USB Port on the Computer; you are lacking the updated printer drivers. Go to Brother on line, plug in the DCP 8040 ( the printer mod.) in the support area, and download the current printer drivers. Install the drivers and see if you can now connect properly. You can also use the Windows DEVICES to locate the printer and check for updates.
SOURCE: printer message says it is offline
Hi
Kindly check the usb cable if its fine then try going into control panel open printer and faxes option & set your printer as default .
Thanks
SOURCE: automatic Document Feeder on my Brother DCP-8045D
are you on Mac or PC. I know h2 do it on Mac
SOURCE: Brother HL-2170W Laser Printer is 'offline" wpm
Is this the initial install? If so do this..
I finally figured this out. Do the "cable" install. After it discovers the printer etc you will get to a screen during the driver part of the install that will ask you how to find the printer. The "recommended" list method is a deadend! Instead, check the IP address option and input that.. You can get the IP address of the printer from the test page which should have already printed.(Its probably 192.168.2.3). I run XP and it solved the problem. I suspect its also the answer for Macs and Vista as well.
I have also had success by doing the "cable" install, then when its done, deleting the printer in Printers and Faxes, then doing a manual install (you still need the IP address). I am using two computers to go to this printer and it flies. Great speed.
SOURCE: UNABLE TO INSTALL MY BROTHER DCP-135C PRINTER/COPIER
Hi!
Please open this link and select the model no. of your printer from there and then it will open up a new window from where you have to choose the drivers you want to install.
Link For drivers.
Do rate the solution
Thanks
Rylee
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Neither is it a prob with the computer nor with the scanner.
Let me guess,
either is your usb connection cable longer than 2m or you have connected the usb printer/scanner cable to a usb hub.
Do use a cable no longer than a max of 3m and do connect the usb cable directly to the computer usb slot.
