Kodak 5500 ALL-IN-ONE PRINTER Logo
Posted on Jul 22, 2011
HI no image or text is being printed..just blank pages
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jul 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
776
Points
34
Your out of ink in your toners just refill or get new ones
How do I Fix Brother printer printing blank pages issue of my Brother printer?
Completely or partially blank pages when printing from ...
Brother-USA https://help.brother-usa.com > answers > detail > a_id
Completely or partially blank pages when printing from Windows or Macintosh computer only. 1. Place a document with text or an image on the flatbed or in the ...
The printer prints blank paper - Brother HL-5240
iFixit https://www.ifixit.com > Answers > View > The+printe...
Sep 5, 2016 Ā· 5 answers
Here are the steps to fix the brother printer printing completely blank pages issue. 1. First of all, you should restart the devices, ...
Fix brother printer printing blank pages
brothersetupsupport.com https://brothersetupsupport.com > fix-brother-printer-...
Jan 23, 2023 - Why brother printer keeps printing blank pages Ā· Ink cartridges have jammed or there is a paper jam. Ā· The printer head is blocked or jammed. Ā· The ...
Color smudging
Hi, either the drum or belt or both become defective.
1helpful
2answers
My Epson Workforce 600 will not print text. It does print pictures but when I try to print text in Word, Excel or any other application, it just shoots out a blank page. If there are any pictures in the...
Had the same problem with Epson WorkForce 545, seemed to print just signature lines on emails, but not the regular text. Called Epson service, they had me go through headcleanings (Setup-Maintenance-Head Cleaning) and afterwards do a "Nozzle Check". Once the Nozzle check printed 6 squares with all the lines, I then reprinted a regular page and voila, it actually printed my text. I think my black print head was totally clogged and that's why it only printed images that used color in them...
Hello, the printer will not print out forms either from a adobe pdf file or from the internet; it leaves the page blank or just prints out the grids but no text.Please can you help?
Hi. Try turning off the image sharpening in the print settings.
For Windows, open the file and go to File > Print > Preferences/Properties in the Print window> Image Enhancement tab in the Lexmark 4500 Series Printing Preferences > choose None for Image Sharpening. Hit ok. Click Apply to save settings. Hit print to start printing. For Macintosh, open the file > go to File > Print > Print Settings > Advanced Settings > Image Sharpening > adjust setting to None. Try to print. Hope this helps. Good luck!
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
29helpful
2answers
Brother MFC 7840 W printing blank pages no text or images
Had the same thing happen. Unplugged the power on the printer and plugged it back in. No problems now.
Printer stopped printing color images
hi im josh in cebu phils .friend may i help you? The problem appears on your print out is a symptoms of software corruption. Try to re install new software driver for printer. but dont forger to uninstall the old one before installing a new. check also the printer port connection. good luck hope i helped you.
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
2answers
Kyocera FS 1010 is printing blank pages
You may need an imaging unit. VERY expensive.
HP Officejet 5610 All-In-One print text but no image?
I found what might be the solution to this while searching for a problem for another printer series on HP's site. Go to the Printed Page Is Different Than What Appeared on Screen page and scroll down to "Missing graphics or text, or blank pages"
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
